Did you know? 🤔
Haldex Oil Change
2001 - 2007 XC-70
XC70Rider
Year and Model: 2007 XC70
Has thanked: 20 times
Been thanked: 19 times
United States of America
XC70Rider
Re: Haldex Oil Change
Post by XC70Rider » Thu Apr 11, 2019 9:26 am
vtl wrote:
Thu Apr 11, 2019 9:08 am
XC70Rider wrote:
Thu Apr 11, 2019 8:33 am
After mounting the shaft I'll fill the Haldex until it drips out of the plug then extract 100ml as instructed by Vida.
Don't. Since you had the unit fully drained, fill it up, go for a ride, come back and check the level. You may need to top it up actually.
Thanks for tip VTL. I guess the VIDA instructions are only when extracting then filling via the plug.
After driving several miles I'll check the Haldex oil level and fill if necessary.
I'll also extract and re-fill the final drive GL-5 fluid. The previous owner didn't use a crush washer on the fill plug so it leaked out and was empty. I presume I saved the differential gears by finding this early enough. I'll check the extracted GL-5 fluid for any metal shavings.
XC70Rider
XC70Rider
Post by XC70Rider » Fri May 10, 2019 7:29 pm
Here's the OEM damper I had to cut in half to get the driveshaft removed.
There is very little clearance room between the damper and Haldex 3. If there was more space I might of been able to force it out with a crowbar using a bolt through the backside.
XC70Rider
XC70Rider
Post by XC70Rider » Fri May 10, 2019 7:32 pm
I cleaned up the Haldex 3 oil pump & filter housing and threw on a new seal.
After mounting the new damper I covered the inside with ball bearing grease.
This will make the driveshaft easier to remove if needed in the future.
XC70Rider
XC70Rider
Post by XC70Rider » Fri May 10, 2019 7:36 pm
Here is the driveshaft mounted into the new damper.
Here is the other end mounted in the bevel gear.
I threw new CV joints on both ends I got from Colorado Driveshafts. The boots are made of nice thick rubber on these joints.
Antoine240bk
Year and Model: XC70 2.5T-2006
Has thanked: 10 times
Been thanked: 14 times
France
Antoine240bk
Post by Antoine240bk » Sat May 11, 2019 4:54 am
Great work! So you had to rebuild both cv joint on the initial driveshaft. Bravo!
Volvo XC70 2.5 T AWD P2 BVA B5254T2 12/2005 Four-C EX : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -Gpl - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
XC70Rider
XC70Rider
Post by XC70Rider » Sat May 11, 2019 5:49 am
The rear CV joint no doubt because I cut the outer casing while cutting the damper. The front one I was able to force out but the thin boot was about to rip so decided to replace it also. When I removed that front CV joint the boot tore apart.
With assistance from VTL and yourself I was able to fully clean out the Haldex.
I've driven her ~300 miles since installing the new haldex oil, filter,damper and CV joints on the drivehshaft and the AWD is working fine. Took pictures yesterday while I had the exhaust removed. I threw on Bosal catback and an Eastern direct fit CAT yesterday.
