IPD sale XeMODeX - Experts in Volvo Electronics Free shipping all USA - Experts in Brakes
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
AC issues - 2002 S60
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
cvega131
Year and Model: 2002 s60
Has thanked: 0
Been thanked: 0
United States of America
cvega131
Post by cvega131 » Tue Jun 06, 2017 11:29 am
Help needed. Ok, so I have an 02 S60 and just today when we got into the car the ac fans were running. The car was off, but fans blowing out air. Now, I'm guessing it is an electrical issue, but wanted to see if anyone else has experienced the same problem. The air, when turned on, blows out cool. I have seen others comment that their ac stops blowing out cool air after a while, but this isnt the case here, at least we hope not yet. Thanks in advance
Reason: Improved title, added tags
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 289 times
Been thanked: 905 times
Trinidad & Tobago
Re: AC issues
Post by abscate » Tue Jun 06, 2017 11:54 am
The P2 cars actually keep the fan on after shut down to dry out the evaporator and stop it from corroding..
Your car might not have any issue to repair. We still charge the same here , though.
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
Botbasher
Year and Model: 98 "R" & 03 T5 V70
Has thanked: 0
Been thanked: 3 times
Botbasher
Re: AC issues
Post by Botbasher » Wed Jun 07, 2017 7:59 am
Yeah... This one freaked me out the first time I had it happen.
I was under the car looking for oil leaks and the fans just come on for no reason! Bet it was funny to watch this big boy come out from under that car like a rabbit on caffeine!!! :lol: :lol: :lol: A little searching on MVS and I find that they are programmable and can be set to come on at different intervals (if at all).
I like the idea of drying out the evap coil, but damn Volvo... give a guy a warning when it's going to come on!! :evil:
K " :shock: " S
Never become a pessimist. A pessimist is correct oftener than an optimist, but an optimist has more fun, and neither can stop the march of events.-Heinlein
We have met the enemy and he is us.-Pogo
If speed kills, do brakes give life??
jimmy57
Has thanked: 3 times
Been thanked: 232 times
jimmy57
Re: AC issues
Post by jimmy57 » Wed Jun 07, 2017 8:50 am
Is this S60 relatively new? If you have had it for a year or more and it never did this then you may have another issue.
The "afterblow" function is enabled to suppress biologicals growth that leads to foul odor from vents. This will only work if the a/c was operated for more than 15 minutes (all times approximate as different software versions tweak the times) and then vehicle is parked and ignition switch is off. Fan will come on approx 40 minutes later and run for 8-10 minutes.
If your fan came on much later or earlier than 40 minutes and ran for much longer than 10 minutes and battery went dead in order to make it stop then you have a problem and it is not afterblow feature.
Botbasher
Has thanked: 0
Botbasher
Re: AC issues
Post by Botbasher » Wed Jun 07, 2017 1:48 pm
If your fan came on much later or earlier than 40 minutes and ran for much longer than 10 minutes....
This must vary greatly then as mine was much less than 40 minutes.
I want to say something like 10-15 minutes as I came back from a drive, jacked up the car, grabbed the parts and climbed under before the exhaust had stopped ticking.
If it's anything like our programming, then time, temp and usage would alter the event timing and duration. Summer temps, sooner and longer (humid)... Winter temps, later and shorter (dry), but that is a straight WAG!!
K "WAGen" S
June
Year and Model: 2004 S80 T6
Has thanked: 267 times
Been thanked: 144 times
June
Re: AC issues
Post by June » Wed Jun 07, 2017 4:18 pm
My 2002 S80 dash fan would come back on after maybe 10 minutes after shutting the engine down and ran no more than 10 minutes. It could have been 15 or 20 minutes after shut down as I frequently would catch it running. Definitely not 40 minutes. My 2004 is like 30 or 40 minutes. I almost never catch the 2004 running the afterblow feature. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
JRL
Year and Model: Several
Has thanked: 0
Been thanked: 12 times
JRL
Re: AC issues
Post by JRL » Thu Jun 08, 2017 7:09 am
It can be shut off if it bothers you
Contact info for purchases: [email protected]
s_watts
Year and Model: 2006 S60
Has thanked: 0
Been thanked: 0
s_watts
Re: AC issues
Post by s_watts » Wed Jun 14, 2017 11:26 am
Ive recently had a very similiar issue with my 06 S60 2.5T. It was after a long drive and the weather was getting pretty hot around here. The fan would continue to blow, but not stop after an hour (Ive found it to be running after 4 hrs), it would run until the next time i got in the car. I had the battery die a couple of times and eventually pulled the fuse and dont have AC now. Now when I plug in back in, I get a faint blow when I turn the AC off, not sure if im imagining it or not. Does this sound like an error with the afterblow feature? I am afraid to leave the fuse in the case that I have a dead battery next time I need to go somewhere. How would one go about turning it off?
cmblackburn
Year and Model: 1998 S70 T5
Has thanked: 0
Been thanked: 0
cmblackburn
Re: AC issues
Post by cmblackburn » Wed Jun 14, 2017 12:11 pm
An '06 S60 2.5T I worked on for a while did this, and I found the problem to be the blower resistor module. Not sure why, but replacing that with a new one stopped it running for hours after turning off the car- it was chewing down the battery. After replacement it would cut on to dry out the evaporator and shut off appropriately.
1998 S70 T5, 267k "The Blue Turd" Dead again, manual swapping
2004 S40 2.4i, 164k "Cosmo"
2001 Ford Escape XLT, 198k "The Magic School Bus"
