Timing marks '04 V70
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Faust
Year and Model: XC70 2005
Has thanked: 14 times
Been thanked: 4 times
Post by Faust »
I have reason to think that my engine has "jumped time". Is there any way to get a look at the timing mark on the crank pulley without pulling the accessory belt and lower cover? I just want to check that all the timing marks line up, or do not.
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 55 times
Been thanked: 206 times
Post by bmdubya1198 »
You don't have to pull the serpentine belt, but you will have to pull the timing belt cover. Then just use a 30mm socket on the crank to turn the motor over and you will see (from the top) two marks on the teeth of the crank pulley that should line up around an arrow on the oil pump.
By the way, this section of the forum is for the P80, 1998-2000 V70. You would want this in the P2 section, 2001-2007 V70.
00 V70R Venetian Red/Charcoal M56 Swapped 202k
03 S60 2.4T Silver/Black 122k
07 XC90 V8 AWD Sport Titanium Grey/Black 180k
98 V70 GLT Black/Beige 205k
00 S70 GLT Mystic Silver/Taupe 254k
99 BMW 528i
84 BMW 318i
04 Saab 9-5 Aero
01 Mountaineer 5.0- to tow all these cars
91 944 Turbo
