Timing marks '04 V70
- Year and Model: XC70 2005
- Has thanked: 14 times
- Been thanked: 4 times
I have reason to think that my engine has "jumped time". Is there any way to get a look at the timing mark on the crank pulley without pulling the accessory belt and lower cover? I just want to check that all the timing marks line up, or do not.
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
- Has thanked: 51 times
- Been thanked: 201 times
Re: Timing marks '04 V70
You don't have to pull the serpentine belt, but you will have to pull the timing belt cover. Then just use a 30mm socket on the crank to turn the motor over and you will see (from the top) two marks on the teeth of the crank pulley that should line up around an arrow on the oil pump.
By the way, this section of the forum is for the P80, 1998-2000 V70. You would want this in the P2 section, 2001-2007 V70.
00 V70R Venetian Red/Charcoal M56 Swapped 200k
03 S60 2.4T Silver/Black 118k
07 XC90 V8 AWD Sport Titanium Grey/Black 174k
92 245 Base White/Beige 249k
98 V70 GLT Black/Beige 205k
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
00 S70 GLT Mystic Silver/Taupe 253k
91 944 Turbo Dark Green/Beige 175k
93 944 Base Beige/Beige 221k
98 S90- Silver/Gray 207k
95 850 GLT Tropic Green... crushed
01 S60 2.4T Black/Black 230k
88 744 Turbo M46 Beige Metallic/Beige 188k
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
