My fault - I thought you had attached a video. I confused it with another similar post.
Regardless, any updates?
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
Timing marks '04 V70 - viewing
- SuperHerman
- Been thanked: 176 times
- Year and Model: XC70 2005
- Has thanked: 14 times
- Been thanked: 4 times
Re: Timing marks '04 V70 - viewing
"Regardless, any updates?
I have the belt cover off, but unable to detect any marks on the crank pulley.
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
- SuperHerman
Again, just pull of the wheel, the one 10mm plastic nut, fold back the plastic access panel and remove the four bolts holding the harmonic balancer.
You will see the mark right away. After this if the gear teeth have markings (which mine did not) they will be now be evident.
I assure you time will be saved.
- SuperHerman
Look at the pictures in the PDF that is in the last post. They show the "marked" teeth for his car - possibly yours is the same.
viewtopic.php?f=9&t=77183
"Again, just pull of the wheel, the one 10mm plastic nut, fold back the plastic access panel and remove the four bolts holding the harmonic balancer."
I'd done all that save pulling the harmonic balancer, I'l;l try that,.
2004 V70
- Year and Model: 2004 V70
- Has thanked: 2 times
- Been thanked: 43 times
Timing marks are visible in this video, you are probably looking in the wrong place, they are not at the 12 o'clock position.
More like 10 oclock .
- 370 Views
Last post by bmdubya1198
- 343 Views
Last post by Mattvh
- 609 Views
Last post by vtl
