Did you know? 🤔
2004 S60 motor -- swap-in 2006 R engine? Possible?
2001 - 2007 XC-70
Chriss444
Year and Model: 2002 S60
Has thanked: 0
Been thanked: 0
United States of America
Chriss444
Post by Chriss444 » Thu Sep 21, 2017 12:46 pm
Hi, I have a 2004 S60 2.5T AWD, love this car, it is my baby- I will try to keep this short- I have a 2006 2.5T "R" motor, out of a wrecked V70R AWD, that I want to put in my S60. I have the ECM and harness with the new motor.
I have been informed by XEMODEX that the new ECM will not work with my car, so my question is - can I install the 06 motor in my 04, then transfer all my current electronics over to the new motor? They are both 2.5T motors.
I understand that the R motor will not run at its full potential, but will it run?
Any advice much appreciated, Thanks!
Reason: improved title
Year and Model: Lots
Has thanked: 4 times
Been thanked: 106 times
Australia
Re: 2004 S60 motor -- swap-in 2006 R engine? Possible?
Post by precopster » Thu Sep 21, 2017 3:46 pm
The ECM has separate engine control and key transponder sections to rewrite if being upgraded or matched. CEM must also be considered and won't match the ECM from the R. In this case the loom won't help. It HAS been done however the guys that have done this have spent big money on custom ECUs.
I would just use the R motor with bigger turbo and have the original ECM upgraded for more boost. Easy and simple.
Current cars:2002 XC70, 2006 Ssangyong Rodius (Stavic), 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
oragex
Year and Model: S60 2003
Has thanked: 92 times
Been thanked: 233 times
Canada
oragex
Post by oragex » Thu Sep 21, 2017 4:14 pm
This guy swapped a used ECM after having it cloned (he calls it ECU in the post). As above, I would also wonder about the CEM working along the cloned ECM. Maybe guys from tuning places could provide an answer. And perhaps some forums from Sweden (as a country) as well, it's their car after all and they seem to be doing quite a bit of mods on it.
viewtopic.php?f=9&t=50291&start=10
Chriss444
Has thanked: 0
Been thanked: 0
Chriss444
Post by Chriss444 » Sat Sep 23, 2017 4:19 am
Thank you very much for the help- I will be taking your advice, and am starting to pull the original motor today.
Australia
Post by precopster » Sat Sep 23, 2017 6:45 am
The R motor will respond well to a boost upgrade with plenty in reserve.
Some of the "custom" tuners like ARD will likely know exactly which tune will suit your particular setup. There was a guy that did exactly what you did in a blue S60 2.5T and he did a ton of custom work like a larger intercooler so the R motor could actually boost properly. Later you may want to look at a larger intercooler after the custom ECM mods. It will be quite a stinger at the traffic lights for sure.
