Help obd voltage
Help obd voltage
Hi got couple problems with my 02 d5, previous owner replaced injectors and inter cooler but still got loss of power and black smoke even on idle. and cant get any software to talk to it. on checking pin 7 has less than 1v when off and 12v when on? is this normal?
- Year and Model: 2006 V70 2.5t
- Has thanked: 1 time
- Been thanked: 2 times
The best bet is using VIDA/DICE, so dealer or an independent VOlvo shop should be able to help you.
The K-line (pin 7) is a communications line, so with an oscilloscope you should see a waveform on there. Not sure if you can tell anything with a voltmeter.
- 2132 Views
Last post by Sommerfeldt
- 31 Replies
- 3161 Views
Last post by dmcfan
- 17 Replies
- 2681 Views
Last post by januwan
- 24 Replies
- 3455 Views
Last post by cjbmustang
- 1023 Views
Last post by Dirk1966
