NEW Parking Brake shoes/cables/rotors but Cable is kind of tight
2001 - 2007 XC-70
pdr1966sc
Year and Model: 2006 V70R
Post by pdr1966sc »
I am almost done installing new shoes, cables, rotors on my 06' V70R.
Cables are Volvo
This car uses the fixed length "H" bar NOT the starwheel adjuster.
I found - even relaxed - that the rotor (new) fit over the shoes was actually pretty snug.
Secondly, I am finding that there is like NO EXTRA cable when trying to hook up inside.
I have the adjuster nut backed way down, so the threaded end of the pull cable is about 25% BELOW the surface (in the hole) of the adjuster nut - I don't dare go more.
Yes to get the cables over the hooks takes a little extra length even so - I am concerned that I am going to actually a have some tension present in the system once hooked - does this seem 'normal' or may I gain a bit once they ARE hooked up and I pull on things a few times.
Not much but my impression is that I wish the cables were like 5mm longer..........
Has thanked: 376 times
Been thanked: 1171 times
Re: NEW Parking Brake shoes/cables/rotors but Cable is kind of tight
The cables are quite tight even when the brake is off - from my recent experience with P2 brakes on my 2005 V70
Pictures in thread - search under '2005 V70NAM56 parking' and you should find it.
Link To Volvo Glossary
pdr1966sc
Post by pdr1966sc »
Thank you, makes me feel better.....knowning I"m not the only one!
Double check those part numbers with your VIN in case there are different parts for 'R' models vs others.
Ive never replaced the cables on mine so I can't guide here.
pdr1966sc
Post by pdr1966sc »
Have it all together now, working nicely, NOT dragging as I feared, cables seated in the spindles, nice action up front with the adjuster nut in a sensible position.
PR
