Hello all,
I recently acquired a 2002 V70 base model for the princely sum of $600 Canadian dollars. When I bought it, it ran, but rough. Here's how far down the rabbit hole I now am:
- Xemodex rebuilt ECM (it now responds when you step on the gas pedal)
- New MAF sensor
- Replaced MAP sensor (used)
- New upstream O2 sensor
- New plugs
- 1 new coil
- new PCV lines (box to head, box to block x2)
- New timing belt, idler, tensioner and water pump
- Coolant flush and refill
- Oil change
- I've tried to find any vacuum leaks, but haven't sound anything obvious so far.
- I'm now finding that I have the dreaded low oil pressure warning, so I've ordered the O-ring kit and will drop the pan to sort that mess out when it comes.
As it stands now, the car starts and runs fairly well although the idle can be a bit rough when cold (it's winter here, so -15°C or so is my starting point). Sometimes it's rough enough to throw a P0300 code, but not consistently. Until it warms up, I have to tap the accelerator to keep the engine from sputtering and I have a hard time keeping it at a constant rpm as it jumps all over the place. once warm, the system seems to settle down and idles nicely.
I have driven the car up and down my driveway, but I haven't got it licensed and insured yet so I can't really take it on the road. I can get up to about 50km/h or so on these tests (I manage to get into second gear), but the car lacks power and doesn't rev up very far under load.
Once the car is completely warmed up and has gone up and down the driveway a couple times, the oil pressure light comes on and I shut it down.
I've ordered a Vida/Dice from eBay, but until it comes, does anyone have any suggestions as to where I should look for problems that would cause the lack of power and the weird idle when cold?
This is a bit different from my last Volvo, an old '82 244...
Thanks,
Miles
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
2002 V70 - rough idle
- RickHaleParker
- Has thanked: 3 times
- Been thanked: 646 times
Re: 2002 V70 - rough idle
Clean out the Idle Air Control (IAC) valve.
2004 S60R, B8444S TF80 AWD.
- Has thanked: 129 times
- Been thanked: 362 times
Engine Coolant Temperature (ECT) sensor is also a possibility. VIDA will help with diagnosing that, however, so may as well wait. I don't know the ohm-temperature graph for a P2 ECT but if you can find that info, that's a great diagnostic route. Or grab one from the junkyard and swap. And since cleaning is cheap, I'd start with the IAC anyway.
'95 854 T5-R, Motronic 4.4, 185k
'96 855 NA, 145k
'98 S70 NA, 220k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
130k
gone: '96 NA 850 210k, '98 NA V70 182k
'96 855 NA, 145k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
- Year and Model: 99T5 ,99S70,2005V70
- Has thanked: 441 times
- Been thanked: 1333 times
erikv11 wrote: ↑Thu Jan 03, 2019 7:44 am Engine Coolant Temperature (ECT) sensor is also a possibility. VIDA will help with diagnosing that, however, so may as well wait. I don't know the ohm-temperature graph for a P2 ECT but if you can find that info, that's a great diagnostic route. Or grab one from the junkyard and swap. And since cleaning is cheap, I'd start with the IAC anyway.
That graph is cross referenced in my P2 Maintenance Log (2005 V70 NAM M56 (separate Forum) or perhaps in my P80 (1999 V70 T5) log, in case searching isn't fruitful
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
- Year and Model: 2002 V70 base
I thought that the IAC function was controlled by the ECM on these non-turbo models. In any case, there isn't a valve unit on the driver's side of the engine like on the turbos and I haven't found any photos.
I guess I can wait for the the VIDA to check the ECT. Would a problematic ECT show any issues at the temperature gauge? mine seems to behave normally... I might pick up another ECT next time I'm out at the wrecker, but its probably not worth going out there just for that (about 45 min drive one way).
Thanks,
M.
Thanks,
M.
- Year and Model: 2007 XC70
- Has thanked: 22 times
- Been thanked: 20 times
Installed the timing belt tensioner in this frigid weather? You must have a heated garage!
I need to wait until it reaches 50f again so my garage can warm up to 70f until I tackle the timing belt.
It's well worth purcashing the VIDA/ Dice unit. I installed it on a refurbished laptop I got on ebay for $136 USD last week. If you do purchase one download and install Rick's Repack:
viewtopic.php?f=40&t=83834
I thought the same thing, but https://www.fcpeuro.com/products/volvo- ... 70-1275634.
They do when they fail, pretty reliably. And throw a CEL. So the idea is maybe it is only a little out of spec, giving wrong air:fuel mixtures.
'96 855 NA, 145k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
130k
'96 855 NA, 145k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
OK, I still can't quite figure out where that IAC would be hiding on this car. I did see other references to it being integrated into the ECM. In any case, I'm waiting for parts so I can do the o-ring job and warmer weather so I can re-adjust the timing belt (my garage is sort of heated with a space heater - it was probably 5°C when I was working out there). Once I'm to the point where I'm not (as) worried that the motor will explode on me, I'll probably be able to do more actual road tests and maybe limp it in to the local shop (while I'm waiting on the VIDA-DICE).
In the mean time, work will be interfering with my tinkering...
Thanks for the suggestions,
M.
M.
OK, so I have my Vida/Dice now working and I'm seeing a few things to rule out some possible culprits: 1) ETM - desired and actual throttle angle are synchronized and doing fine. 2) Mass air flow and Manifold absolute pressure are giving consistent readings without any unexpected blips along the way (basically flatline at idle, moves with engine speed) 3) I'm getting misfires on cylinders 1 and 5 so I changed all the coils. That seemed to help, but they still misfire until the engine warms up (and it's still bloody cold out!!).
I'm wondering about the periodic (mostly downward) spikes in the ECM-actual spark advance line. Anybody know what I should look at now? I drove the car up and down the driveway again (enough to shift into second), but it seems to lack power when I step on it. Thoughts?
What other graphs should I be looking at?
Thanks,
Miles
Thanks,
Miles
ECT seems fine as per this graph (blue line) - solid just above 60°C
Would a failing VVT solenoid behave like this? Cam position sensor?
Thanks,
M.
Thanks,
M.
- 696 Views
Last post by jonesg
- 248 Views
Last post by dnmcfarla
- 61 Replies
- 2692 Views
Last post by balzybenzy
