IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
2006 xc70 breather (PCV) system
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
jimpierce7
Year and Model: 2006 XC70
Has thanked: 0
Been thanked: 0
United States of America
jimpierce7
Post by jimpierce7 » Fri Jan 04, 2019 1:26 pm
As I am believing the videos I've seen, when I do the glove test it does not suck in to the oil fill or the dip stick. Doesn't really blow up either but the videos I've seen it's real obvious that there is a suction there.
190k miles so it's probably due. :D Seems I'll need a clamp crimping tool for the vacuum lines. The rest looks pretty straight forward from what I have seen.
Anything special I should know?
My timing belt will be what comes after this.
What is best for cleaning up the gasket surfaces? Been awhile since I've done it and what I have is a wire wheel.
Recommended places to get the breather kit?
jimpierce7
Has thanked: 0
Been thanked: 0
jimpierce7
Re: 2006 xc70 breather (PCV) system
Post by jimpierce7 » Fri Jan 04, 2019 1:32 pm
Sorry, so I don't lose the number
Volvo part #30731007 crankcase breather hose nipple
oragex
Year and Model: S60 2003
Has thanked: 97 times
Been thanked: 286 times
Canada
oragex
Post by oragex » Fri Jan 04, 2019 7:27 pm
If it doesnt suck in, it's bad
Crimping tool off Ebay https://www.ebay.com/itm/CV-Joint-Boot- ... ect=mobile
Surfaces with a steel sponge (quality one). I took 30 min to clean the manifold znd give it a fresh paint
New manifold and throttle body gaskets I believe
Replace the ptc nipple or clean well
Lower left manifold bolt may need a 1/4 or 3/8" swivel joint to reach
Right time for the thermostat as well ($100)
Vaseline on the injectors seals before placing back, and clean the seals really well so they don't leak. To pull the rail I use a pry bar as the seals get stuck in there.
jimpierce7
Has thanked: 0
Been thanked: 0
jimpierce7
Post by jimpierce7 » Fri Jan 04, 2019 8:52 pm
I was thinking the thermostat might be a good idea.
The video I saw mentions that the lower left manifold bolt can't come all the way out due to the thermostat housing? Am I right that replacing the t-stat would make it so I am able to pull that bolt and not have to cut the gasket?
oragex
Canada
oragex
Post by oragex » Sat Jan 05, 2019 1:59 am
I think yes, but accessing the recessed lower tstat bolt may be harder (maybe with a 1/4 extension?)
Cutting a small piece of the manifold gasket is safe and quick, the genuine gasket at least is made of a think paper (and the bolts have low torque)
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 124 times
Sweden
Rattnalle
Post by Rattnalle » Sat Jan 05, 2019 5:23 am
I replaced my gasket thermostat in place. No issues. The entire row of lower bolts you only loosen to take the manifold off then you take them out to replace the gasket when there's room to work.
A 1/4 wobble extender was enough for me to get to the lower left manifold bolt.
jimpierce7
Has thanked: 0
Been thanked: 0
jimpierce7
Post by jimpierce7 » Sat Jan 05, 2019 3:30 pm
There sure are a lot of options for kits. Wow. And they don't seem to be just one having more than the other.
jking4020
Year and Model: 1997 850, 2001 v70xc
Has thanked: 0
Been thanked: 0
jking4020
Post by jking4020 » Sat Jan 05, 2019 4:39 pm
Major yes on the wobble socket extension. You don't need to change your manifold gasket. Once you get it all taken apart blow through all the pieces to see what's clogged. There's two lower ports into the engine block that needs to be cleaned out usually. Once its clean blow air in the motor through the lower ports and hopefully you'll get air coming out the top oil fill cap. If you do then you're good. Put on the new pieces you need. If you don't get air through the motor it probably means you have to drop the pan to clean out more gunk. I also recommend draining the radiator a bit so you can take off the top radiator hose. Do NOT pull the hose out of the way. You can crack the cheap plastic radiator where the hose goes in. And be very careful with the fuel rail. I don't know about a pry bar. All you have to do is give a nice little yank and it pops out. And if you're a space cadet like me you may want to Mark each end of the vacuum lines according to where they came off. Sometimes I've forgotten where they go back on. Good luck. Its really not a hard job.
xHeart
Year and Model: 13XC90/01V70X/97N854
Has thanked: 22 times
Been thanked: 44 times
xHeart
Post by xHeart » Sat Jan 05, 2019 6:37 pm
That bottom corner screw is a straight shot from under the steering pump. It doesn't need complete removal for taking out inlet manifold. In fact all three bottom screws are straight shot from underneath manifold -- avoid wobble if you can.
This may help a little: viewtopic.php?f=9&t=61449
Golden Retriever | 2014D VIDA DiCE | 2013A XC90 +144mi/231km | 2001 V70XC 1st Owner +200mi/ +322km | 1997 Volvo 850 NA 1st Owner +180mi/ +289km
Past: German Shepherd | 1989 Volvo 740 GL | 1979 Volvo 240
dlundblad
Year and Model: 2002 S60 2.4t
Has thanked: 6 times
Been thanked: 3 times
dlundblad
Post by dlundblad » Sun Jan 06, 2019 3:52 pm
If you replace the candied line, you might as well replace the lower radiator hose too because it'll be in your way for the driver side rear banjo bolt.
I second a thermostat replacement. Wish I would have done that actually.
When you do your timing belt, you might as well do the water pump and consider the cam seals. I replaced the entire PCV and all seemed well only for the seals to need replaced a year later.
Hers: Charcoal 2002 S60 2.4t 187k
