IPD sale XeMODeX - Experts in Volvo Electronics Volvo modules repair and programming
Please use the MVS Amazon link when you buy anything at all! It helps this site. Thanks very much!
Can a FWD transmission be converted to work with AWD
2001 - 2007 XC-70
boostedxc
Year and Model: 2004 XC70
Post by boostedxc »
I hope this doesn't sound like a dumb question, but I have a very low mile transmission from a FWD S60 and I'm hoping I could somehow make it so a transfer case could bolt up to it and use it in an AWD car. So will it work or is there no way to convert it?
Been thanked: 158 times
Re: Can a FWD transmission be converted to work with AWD
Post by cn90 »
For some reasons, I thought the Trans is the same for both FWD and AWD versions?
May be I am wrong...
jimmy57
Been thanked: 271 times
Post by jimmy57 »
No. The final drive for FWD will not have the splines to drive the angle gear. The FWD case has a small opening for RH axle that i too small for the AWD collar. If the FWD trans is similar year and from a turbo engine car it will have the same internals and gearing and could be put in the AWD case and use the final drive from the AWD trans.
boostedxc
Post by boostedxc »
jimmy57 wrote: Sun Feb 03, 2019 9:00 pm No. The final drive for FWD will not have the splines to drive the angle gear. The FWD case has a small opening for RH axle that i too small for the AWD collar. If the FWD trans is similar year and from a turbo engine car it will have the same internals and gearing and could be put in the AWD case and use the final drive from the AWD trans.
That's what I figured, thanks!
cn90 wrote: Sun Feb 03, 2019 8:35 pm For some reasons, I thought the Trans is the same for both FWD and AWD versions?
It is, minus the transfer case. However there are holes on the FWD for the transfer case to bolt up to. But like jimmy said, the shaft is smaller.
jimmy57
Post by jimmy57 »
Is it a turbo FWD trans?
IslandV70
Year and Model: 2005 V70 2.4
Has thanked: 2 times
Post by IslandV70 »
Can you just not add the AWD parts and make a FWD car?
Daveliz99
Year and Model: V70 2001
Has thanked: 3 times
Post by Daveliz99 »
Here is a link to a thread where a guy says he did make the conversion. He says he went from a 5 speed auto, apparently in an AWD car, to a M56 from a FWD car. It’s the last post in the thread.
viewtopic.php?p=484461#p484461
boostedxc
Post by boostedxc »
jimmy57 wrote: Mon Feb 04, 2019 12:27 pm Is it a turbo FWD trans?
Yes, both turbos.
Daveliz99 wrote: Mon Feb 04, 2019 6:13 pm Here is a link to a thread where a guy says he did make the conversion. He says he went from a 5 speed auto, apparently in an AWD car, to a M56 from a FWD car. It’s the last post in the thread.
Thanks, that's good information.
