Book rate for belt, tensioner, And water pump is 4.3 hours
What problems to expect on V70 2006 after 200,000 km
- Year and Model: 99T5 ,99S70,2005V70
- Has thanked: 443 times
- Been thanked: 1339 times
Re: What problems to expect on V70 2006 after 200,000 km
Link To Volvo Glossary
- Year and Model: 2007 XC70
- Has thanked: 2 times
When I did my XC70 it took me pretty much all day in my garage working at it slowly to do the TB, all pulleys, serpentine & all pulleys.
I can see how someone that's done it before should be good with half that time.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 322 times
You don't need to do the water pump at 200000 KM (not miles). Let it there until 300000km unless a previous owner did replace it with a cheap aftermarket part. This pump is unlike ones on a BMw or Honda, it lasts usually the life of the car. It's also expensive because we only put Aisin (all other brands may fail all of a sudden after few miles). It also takes time to remove because if has a gazillion bolts on it hard to reach. Plus you will need new coolant (use genuine from Volvo mixed with distilled water from Walmart pharmacy by the gallon)
Really careful what parts you use and careful which mechanic you pick, Montreal is shady about garages. Modulepro is an ex volvo tech, he is honest https://www.google.com/maps/place/Modul ... 32!9m1!1b1
Also heard good things about Sweedish Auto but perhaps more expensive https://www.google.com/maps/place/Swedi ... 73.6096097
2-3 hours for timing belt at a smaller garage, plus parts - use only Continental belt and tensioner
The PCV is indeed a 2-3h job + parts at a small honest garage, in fact it can be done in 1.5h on a non turbo but garages ask more. A Volvo dealer will perhaps charge 4h+. You will perhaps need just the box, can get it from Eeuroparts.com ask them which shipping service has custom fees paid upfront for Canada. A Volvo specialist will also have it
These guys sell parts for european cars https://www.google.com/maps/place/Autol ... 73.6641808
Well, I decided to give a try to replace the timing belt myself and let the PCV to my mechanic.
I think I will go with oragex recommandation and let the water pump there. So I will buy a kit with the timing belt, tensioner and idler. Since I'm there, I will change the serpentine belt as well, so I will add the belt and the tensioner. Do I need to change any seals, or that is all I need ?
Thanks very much !
Thanks very much !
Dynamic D
Labor on a timing belt is only about 2 hours once you get practiced. Leave all the seals alone if they are not seeping, circle back if they leak and do them later.
Have a close look at your water pump and if it isnt seeping, leave it in. At 230k miles on my original on my 1999, just under 400k km
Im up in Montreal in a few weeks, too.
- Year and Model: 2008 S60
- Has thanked: 3 times
- Been thanked: 4 times
What was your logic for leaving PCV to mechanic? FCPEuro has a good video on the PCV job. There are some tight spots and removing intake manifold can be tricky, but I don't think it is any more complicated than TB job.
My opinion is heavily biased, however, by my overall philosophy that if I can't fix it, I don't want to own it.
- 996 Views
Last post by sleddriver
- 192 Replies
- 7243 Views
Last post by xHeart
- 639 Views
Last post by cgw4jesus
- 10 Replies
- 1131 Views
- 890 Views
