IPD sale XeMODeX - Experts in Volvo Electronics Volvo modules repair and programming
Please use the MVS Amazon link when you buy anything at all! It helps this site. Thanks very much!
Radiator fan runs continuously
2001 - 2007 XC-70
BryonTheCanadian
Year and Model: 2006 XC70
Post by BryonTheCanadian »
Hi team my rad fan is now running on high from the second i switch on the car cold... If read it could be a defective part on the fan unit or high pressure switch on AC condenser... My Ac does not seem to be working so could be that.. Is there an easy way to disable the high pressure sensor to remove it from the equation? to see if its the Fan electronics... or other ideas B
RickHaleParker
Has thanked: 3 times
Been thanked: 621 times
Re: Radiator fan runs continuously
Post by RickHaleParker »
BryonTheCanadian wrote: Tue Apr 23, 2019 11:23 am Is there an easy way to disable the high pressure sensor to remove it from the equation?
1. Disconnect the wire to the A/C clutch so that it cannot be engaged.
2. Pull the wires on the A/C pressure switch and put a jumper across the two wires. 1/2 of a paper clip makes a good jumper.
3. Tape it so it does not get shorted.
If the fan runs correctly you found the source of the problem and can run this way until you get the A/C fixed.
2004 S60R, B8444S TF80 AWD.
cbova
Year and Model: 2005 XC70
Post by cbova »
Did you find a solution to this? Mine started doing the exact same thin last week. I'll start a new thread with what I've checked so far so not to hijack.
BryonTheCanadian
No have not checked much out. seems it could be 1 of two things either Fan switch or high pressure sensor on AC
BryonTheCanadian
RickHaleParker wrote: Tue Apr 23, 2019 11:40 am
Thanks Rick where would the AC pressure switch be located... Thanx
