Did you know? 🤔
Start prevented try again, again
2001 - 2007 XC-70
RickHaleParker
Has thanked: 3 times
Been thanked: 492 times
United States of America
RickHaleParker
Re: Start prevented try again, again
Post by RickHaleParker » Sun May 05, 2019 7:41 pm
You accomplished something, you eliminated the battery as the cause.
1. Antenna ring eliminated.
2. Battery eliminated.
Did you do the lock/unlock with the good and charged battery in?
Next suspect:
Open-circuit in the communication between the central electronic module (CEM) and the engine control module (ECM). These cars will do this when the connectors on the CEM works loose.
You should get a diagnostic scanner and pull the codes.
VIDA/DiCE is the recommended diagnostic scanner.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
SVO LOU
Year and Model: 01 V70 XC, 06 V70
Has thanked: 11 times
Been thanked: 0
SVO LOU
Post by SVO LOU » Mon May 06, 2019 9:16 am
You're right, a couple of things have been eliminated and thank you for that, sometimes you need that little bit of encouragement.
I tried the 5x lock/unlock thing with no changes.
Found a video to go into diagnostics (DIM diagnostics?) where you hit the turn signal read button along with the rear driving light button for the DTCS menu. As I scroll through I "ass"ume it's checking each module, and when I reach the CES I have a message that sounds like a code is set but it doesn't give a number, is the vida/dice more precise than that?
I've also heard of the CEM having loose connectors in other posts but haven't been able to remove mine to re-seat the plugs, and because of its location, finding a good video diy is difficult.
Thanks again.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Mon May 06, 2019 11:48 am
I have yet to see anybody post useful "DIM diagnostics".
I think the "DIM diagnostics" is to get one stirred up enough to go to a dealer.
VIDA/DiCE is much more precise, it will give you the exact DTC.
There is a 10mm bolt holding the main CEM connector in place. See the file in the link.
CEM removal instructions - XeMODeX
SVO LOU
Been thanked: 0
SVO LOU
Post by SVO LOU » Tue May 07, 2019 1:49 pm
Appreciate the file. I was able to remove the CEM and re-seated the relays but no there was no difference when I connected the battery terminal again. Tried the lock/unlock sequence again, also.
You're definitely right about the vida/dice scanner, but kind of scared since I really don't know what I'm looking for...There are import ones, used ones, then, on top of that, have to worry if my current laptop works with it. Maybe I can find a local enthusiast group that'll take mercy on me and let me borrow one but I'm on the look out.
Thanks again, Rick.
