Remembered this from doing the 1999-on PCV
You put the banjo on the fitting, with the two copper washers, then you put a sacrificial orings on the bolt to hold it together. Once you get the banjo started, snip the oring and pull it off.
You can also snag the oring with a pick and pull it off until it breaks
I spent the same three hours figuring that out.
P80 P2 late PCV banjo bolt tip 31325709
- Has thanked: 483 times
- Been thanked: 1425 times
Bump to move over to the P2 Forum where it applies everywhere...
- Rattnalle
- Has thanked: 20 times
- Been thanked: 124 times
Neat trick.
I fudged it by using some random washers from a drawer with dabs of grease on them to seal after I'd lost the proper ones once too many and couldn't find them again..
You can’t pick up copper sealing rings without a copper magnet, either.
- 662 Views
- 1772 Views
Last post by Ta305
- 13 Replies
- 3460 Views
Last post by tcatlanta
- 736 Views
Last post by oragex
- 1385 Views
Last post by precopster
