Did you know? 🤔
Lower control arm and CV boot, should I bother?
2001 - 2007 XC-70
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 35 times
United States of America
vtl
Re: Lower control arm and CV boot, should I bother?
Post by vtl » Tue May 21, 2019 8:27 pm
XC70Rider wrote:
Tue May 21, 2019 8:23 pm
Original seals aren't leaking yet. Should I push in the originals and follow with the new matching Corteco seals?
Using the new Corteco seals I'll search for a socket or pipe to push them in. The right seal is twice the size of left seal.
Why are you replacing the seals that do not leak? They almost never leak if the differential bearing sits tight.
2005 XC70 260k
2016 XC60 40k
XC70Rider
Year and Model: 2007 XC70
Has thanked: 20 times
Been thanked: 17 times
XC70Rider
Post by XC70Rider » Tue May 21, 2019 8:36 pm
I've gone by the theory to always replace seals when throwing on axles.
I'll inspect the seals when I pull the axles. If they appear in good shape then I won't pull them nor push them in further.
gcha8e
Year and Model: 2005 S60 2.5T AWD
Has thanked: 13 times
gcha8e
Flip the wheel stops, no need to replace :)
Post by gcha8e » Sun Aug 11, 2019 7:27 pm
Hello again! I finally borrowed a car to get this done. I have successfully removed the left axle and inspected the boots, thanks to the tip I found on the site for using a wood chisel to pop the axle out of the transmission. Thanks MVS! (No tranny fluid did come out, thankfully). The inner boot is in good condition, the grease is leaking from the irregular shaped contoured edges (close to the transmission) which fit around the inner joint box.
The inner boot is in good shape and I plan to keep it on and merely add grease and a new clamp - so I don't have to disassemble the inner joint and risk screwing up the bearings. I inspected the inside of the inner joint by sliding the boot down and looking in there and I was surprised that there was still a fair amount of grease in there in spite of it being all over the car.
Sadly the outer boot, which was not leaking, was damaged while removing the steering knuckle. I tore a hole it because the strut came down firmly on it and while I wiggled the strut around the jagged rusty bottom of it pierced the boot.
Thanks in advance for any tips and words of caution as I reassemble! I am uploading a video of my torn boot as a lesson for others, and of my tip to reuse the wheel stops on the opposite side of the car. Will post it soon.
gcha8e
gcha8e
Post by gcha8e » Sun Aug 11, 2019 7:56 pm
Here is me both happy that I got the control arm off, and a bit sad because I tore the boot up.
