Xc70 fuel pump issue
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Matt76brown
Year and Model: 2007 xc70
Post by Matt76brown »
Hi there people.
I recently ran out of fuel. Ran tank dry. Went back with a jerry can, 20L.
Tried starting..... nothing.
Cranks but no fire.
No fuel at rail.
Checked 2 pin plug under back seat to pump and have 12v switched feed.
Also have 12v at large plug on top of pump.
Pump not pumping.
Is there a certain pin to check ?
Can i try powering pump of a battety ? Some help would be awesome.
Thankyou
RickHaleParker
Has thanked: 3 times
Been thanked: 661 times
Post by RickHaleParker »
Check you fuel filter.
Sometimes when you run a tank dry a mass of debris gets pushed into the fuel filter and clogs it. The pump may not be running because it detects pressure in the line. The clogged fuel filter prevents the fuel from reaching the fuel rail.
Matt76brown
I have taken the hoses off the filter before and after and still no luck
RickHaleParker
You may of burned up the fuel pump. Fuel does double duty as the coolant for the pump.
You can try hooking 12V up direct to the pump motor. Just keep in mind it needs to be keep cool.
