IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
HVAC Woes
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
rtfact32
Year and Model: 2001 V70 T5 M65
Has thanked: 0
Been thanked: 0
United States of America
rtfact32
HVAC Woes
Post by rtfact32 » Thu Aug 01, 2019 4:19 pm
Hello everyone! I've lurked in the posts for some time now and have repaired many things on my V70 from the wonderful information here. This is my first time posting, and I apologize if this has been answered someplace else. I haven't seen this exact same problem, however...
I have a '01 V70 T5 M65 that I absolutely love. I purchased it used 2 years ago with ~217k and it currently has ~265k. I've done quite a bit of work (timing belt, struts, ETM, etc) and I recently had the radiator and heater core replaced. I would have done it myself but I ran out of time.
#1 Now my AC isn't working - and it had been before. I've already done the zip-tie fix to the AC clutch and it was fully charged by the garage that did my repairs, but after initially working it slowly starts to fade. I'm thinking this is a leak somewhere in the system, possibly something wasn't tightened down properly after the radiator/heater core repairs. Thoughts?
#2 The HVAC has never worked quite right (failed blend door actuators) which I can deal with, as long as I can make it hot or cold I'm fine. But after the heater core repair, the airflow seems to be focused on the passenger side - 75% of the airflow comes out the passenger side, 25% the driver's side. Thoughts?
and last but not least:
#3 There seems to be a warm air-flow that is coming from under the dash on the driver's side. I've noticed this since I've had the car, but it is either a) fine in the colder months, or b) overpowered by the AC if it's hot. Now that my AC isn't working it's quite unbearable. Thoughts?
If these questions have been answered elsewhere, please direct me there, otherwise, I'd really love to hear what the group thinks and where I should start looking.
Thanks in advance!
2001 Volvo V70 T5 M65
1973 Volvo 164 4-speed
rtfact32
Has thanked: 0
Been thanked: 0
rtfact32
Re: HVAC Woes
Post by rtfact32 » Thu Aug 01, 2019 4:28 pm
Okay, it looks like I didn't look hard enough - the hot air on the driver's side footwell could be this:
viewtopic.php?f=9&t=64147&p=335460&hilit=HVAC#p335460
I'll investigate further.
MDK
Year and Model: 1998 xc 70
Has thanked: 0
Been thanked: 28 times
MDK
Re: HVAC Woes
Post by MDK » Thu Aug 01, 2019 4:59 pm
It kinda sounds like a blend door issue. Anti freeze constantly runs through the heater core and maybe it's not put back together quite right. Or it might be the HEAD which is the HVAC control panel. Is the A/C is holding a charge? You can check that will gauges if you have them. Just have to go through your check list..MDK
rtfact32
Has thanked: 0
Been thanked: 0
rtfact32
Re: HVAC Woes
Post by rtfact32 » Thu Aug 01, 2019 5:04 pm
It's not holding a charge for sure, I've checked with gauges and did a refill just to be sure.
E Showell
Year and Model: V70R '06 AWD Auto
Has thanked: 20 times
Been thanked: 70 times
E Showell
Re: HVAC Woes
Post by E Showell » Thu Aug 01, 2019 6:55 pm
An often overlooked source of problems with A/C systems is a bad Schrader valve on the fill tube. Cheap to replace part wise, but you need a valve core removal tool.
'99 V70 NA FWD Auto, dark blue (actively for sale)
'06 V70 R AWD Auto, Sonic Blue Metallic
'04 XC70 Ruby Red Metallic
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
MDK
Has thanked: 0
MDK
Re: HVAC Woes
Post by MDK » Thu Aug 01, 2019 7:53 pm
As far as leak detection... I know that they have the dye that they put into system with the special glasses. The easy way is to put some Dawn and water in a spray bottle and look for bubbles. It's not that easy to do the evaporator though. O rings on the compressor leaking... Who knows?Just have to pressurize the system..
Roger_850T
Year and Model: 854T 1995
Has thanked: 0
Been thanked: 14 times
Roger_850T
Re: HVAC Woes
Post by Roger_850T » Thu Aug 01, 2019 9:02 pm
I would just take the issues on one at a time. Find the leak, and fix it. Sometimes soap and water works. I have a "halogen detector" which has a little sniffer wand, and makes noise when it picks up a halogen (refrigerant), which works reasonably well. It's good for checking hose connections vs. a bad evaporator. (Because I *always* want to find the problem first, *then* fix it, as opposed to shotgunning parts at it and hoping something works.) Once you find and fix the leak, then you can move on to figuring out the door issue. But one thing at a time, or you'll drive yourself batty!
Roger
'05 XC90 V8 140k
'95 854T 310k
'02 V70 159k
'03 S80 111k (crashed)
'93 945T 217k (gone to be parted out)
'87 245 300k+ sold, still going
'84 264 Diesel, RIP at 160k
'78 242 manual everything.
'73 P1800ES, fun until the rust set in...
chrism
Year and Model: S80 / 2005
Has thanked: 0
Been thanked: 23 times
chrism
Re: HVAC Woes
Post by chrism » Thu Aug 01, 2019 11:07 pm
There are plastic blend door actuators on both the LH and RH sides of the HVAC unit. The actuators on the drivers side tend to interfere with the removal and replacement of the heater core especially if they weren't “parked” in the correct position before beginning the disassembly. This can result in a broken actuator arm and disfunctional blend doors (too much hot air mix). Of course the hot air intrusion isn’t obvious until the engine warms up a bit so you may have decent cooling for the first couple minutes. Thank goodness the dealer sells these actuators, or they may be called “linkages”????
Good luck with the troubleshooting!
rtfact32
Has thanked: 0
Been thanked: 0
rtfact32
Re: HVAC Woes
Post by rtfact32 » Fri Aug 02, 2019 8:57 am
Thanks for the reply - but would this cause low/restricted air-flow as well?
chrism
Has thanked: 0
chrism
Re: HVAC Woes
Post by chrism » Fri Aug 02, 2019 12:21 pm
As I recall those linkages drive a couple different flapper doors on each side of the unit. I believe it could be affecting the overall flow especially if the problem is only on one side of the car.
Is the airflow ALWAYS slow on that side or only after you run the AC for a while?
