Did you know? 🤔
2001 V70 Xc Car locks itself. Wiring or Module? Topic is solved
2001 - 2007 XC-70
daughtersmechanic
Year and Model: 2001 V70 XC
Has thanked: 5 times
Been thanked: 0
United States of America
daughtersmechanic
Re: Car locks itself. Wiring or Module?
Post by daughtersmechanic » Wed Aug 07, 2019 11:18 pm
MoVolvos wrote: ↑
Tue Aug 06, 2019 7:16 pm
I think you should back up a little. Remove one at a time each splice and take a look at the connection. Nothing too hard at all. Solder if you feel the wires are not bound together well.
Re-read my previous post, Mo (Aug 5, 12:57am). "I removed them, and the two wires attached to the door lock wires mentioned previously"
I'm not a fan of solder in places that see a lot of movement (maybe because I stink at soldering), so I used a crimping connector with a heat shrinking cover for water resistance.
Hoping that eliminates the phantom locking. Thanks for your concern and input.
2001 XC70, The Beast, 222K
daughtersmechanic
Been thanked: 0
daughtersmechanic
Post by daughtersmechanic » Wed Aug 07, 2019 11:49 pm
abscate wrote: ↑
Mon Aug 05, 2019 4:14 am
I thought the driver door key opens the driver door mechanically, ...
Once again, we have a winner! There is, indeed, a rod going from the lock mechanism up to the lock cylinder. Here's a view of the (disconnected) end of it, through one of the access holes in the door:
Here's a view from below-
Note the hole in the bracket circled in yellow.. Looks like the end of the rod (circled in red) should go in that hole. I'm able to do that, but it quickly falls out, as the hole is pretty large. Wondering if there should be a rubber grommet in there, or I saw mentioned in another thread something about a plastic clip that holds it in place. Can anyone confirm, or offer an alternate explanation of how to fasten the rod in place?
daughtersmechanic
Been thanked: 0
daughtersmechanic
Post by daughtersmechanic » Wed Aug 07, 2019 11:52 pm
chrism wrote: ↑
Wed Aug 07, 2019 6:21 am
If your old DDM has a little white sticker with two or three numbers on it then you want to match those numbers to the sticker on the replacement DDM. I replaced mine a couple years ago with a junkyard part and as I recall I was able to match two of the three numbers. I also made sure the replacement came from the same year car. End result - it worked.
I'll keep this in mind if it comes to this. Thanks!
daughtersmechanic
Been thanked: 0
daughtersmechanic
Re: Car locks itself. Wiring or Module?  Topic is solved
Post by daughtersmechanic » Thu Aug 08, 2019 1:34 pm
1A Auto and Sue to the rescue! Youtube video https://www.youtube.com/watch?v=YmxLDSXNW0s shows how to remove the driver side handle (on a 2002 V70), and reveals this:
There should be a grommet in that hole in the arm attached to the key lock!
I really think I'm on the home stretch here. Thanks again to MoVolvos, Abscate, & Pete. And, of course to Al Gore for creating the internet! :wink:
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 23 times
Been thanked: 44 times
MoVolvos
Post by MoVolvos » Thu Aug 08, 2019 2:45 pm
daughtersmechanic wrote: ↑
I think Al should get all the Gory for interconnecting us. By the way, I used one of the grommets in this kit and it worked for my 03 S80 T6.
https://www.ebay.com/itm/180-pc-Rubber- ... 2749.l2649
That part is really cheap as someone in the forum recently had the same issue and picked up the part from Volvo. Suppose to be under $2.00.
For future reference you can get the diagrams here.
https://www.volvopartswebstore.com/
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
daughtersmechanic
Been thanked: 0
daughtersmechanic
Post by daughtersmechanic » Fri Aug 09, 2019 6:06 am
I can't tell you how many times, and for how long, I've stared at that diagram, Mo. And every time, it looks to me like that grommet (or bushing, as it's called in the diagram) is associated only with the door handle link, not the lock cylinder link. It took seeing the actual mechanism, properly assembled, to fully understand.
E Showell
Year and Model: V70R '06 AWD Auto
Has thanked: 7 times
Been thanked: 41 times
E Showell
Post by E Showell » Sun Aug 11, 2019 5:32 am
The Beast, eh? Sure it shouldn't be called Hal? Your name isn't Dave is it?
'99 V70 NA FWD Auto, dark blue (actively for sale)
'06 V70 R AWD Auto, Sonic Blue Metallic
'04 XC70 Ruby Red Metallic
daughtersmechanic
Been thanked: 0
daughtersmechanic
Post by daughtersmechanic » Mon Aug 12, 2019 10:16 am
E Showell wrote: ↑
It's a moniker inspired by fear, frustration, and awe.
  • Fear, because it has stranded my daughter numerous times since she got it. "Open the driver's door, Beast." "I'm sorry, but I can't do that."
  • Frustration, because there are so many things that need fixing that I made a list (and I hate lists). Though, when I last cleared codes, only three popped up on the restart (down from 11)
  • Awe, because it's still running, even though she does less than the minimum to maintain it. Most egregious case in point: when I replaced the starter three weeks ago, good dad that I am, I thought I'd just check the oil and top it off if needed. Pulled out the dipstick; no oil visible. Took four quarts to get between the min/max marks.
The good news is that the grommet/bushing for the door lock arrived today. Wish me luck getting the door handle out, and putting the door back together tonight.
E Showell
E Showell
Post by E Showell » Mon Aug 12, 2019 11:49 am
I guess I am showing my age. The "Hal" reference was to Kubrick's masterpiece -- 2001: A Space Odyssey -- where [SPOILER ALERT] the A.I. Computer on the spacecraft named H.A.L. refused to open the pod bay door for the astronaut, Dave.
daughtersmechanic
Been thanked: 0
daughtersmechanic
Post by daughtersmechanic » Mon Aug 12, 2019 2:36 pm
And, I guess I'm showing how obtuse I can be. I acknowledged your reference under the "Fear" bullet point (can you name the actor who played Dave?). But, then I got literal and tried to justify the nickname. We're too smart(-ass?) for our own good! :roll:
