IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
2001 Volvo S60 TCM E000
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
Alexis2929
Year and Model: 2001 S60
Has thanked: 6 times
Been thanked: 0
United States of America
Alexis2929
Post by Alexis2929 » Wed Aug 14, 2019 8:05 pm
My Volvo S60 has in intermittent shifting issue. At times it shifts super smooth but then at others it’s horrible. It gets stuck in neutral when shifting and then shifts hard. Sometimes it slips when driving. I’ve noticed that the transmission tends to shift better when the car isn’t at running temp yet.
there is no check engine light but I found TCM E000 transmission control module faulty communication
I’m guessing that the contact points are dirty but i don’t know what this code means.
Do you guys know anything that could help me?
RickHaleParker
Has thanked: 3 times
Been thanked: 544 times
RickHaleParker
Re: 2001 Volvo S60 TCM E000
Post by RickHaleParker » Wed Aug 14, 2019 8:22 pm
TCM-E000 Control module communication. Faulty communication
Diagnostic trouble code (DTC) information TCM-E000
Condition
The control modules transmit and receive information via a standardized serial communication method - CAN (Controller Area Network). The diagnostic trouble code (DTC) is stored if the control module registers serious interference (CAN communication blocked).
Note! In the event of system communication problems, it is not possible to communicate with the control module. Therefore it will only be possible to read off the fault if it is intermittent.
Substitute value
Control module shuts itself off ("bus-off").
Hint:
The control module will remain shut off until the power supply is broken (15, 30, X). When the power supply is connected the control module will make a new attempt to communicate.
Possible source
  • Short-circuit between the control area network (CAN) wiring
    Open-circuit in the control area network (CAN) wiring
    Damaged pins on Transmission control module (TCM).
    Internal fault in the control module
    Internal fault in another control module in the same part of the control area network (CAN). ECM, ETM, TCM, ABS SAS.
The low hanging fruit is to clean and inspect the connector to the TCM.
Fault symptoms
No shifting.
Text window and warning symbol/Yellow symbol and text message
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
MDK
Year and Model: 1998 xc 70
Has thanked: 0
Been thanked: 28 times
MDK
Post by MDK » Fri Aug 16, 2019 5:05 am
Wow.. Rick Hale Parker... MDK here. I can't really help this person but RHP.. what an avalanche of information!! It's good to know that someone out there has the electronic side of these Volvo's sheesh...
Year and Model: 2001 V70
Has thanked: 28 times
Been thanked: 61 times
Post by volvolugnut » Fri Aug 16, 2019 11:38 am
If you want to read more about the CAN bus system and E000 code, see
www.s80.dk/Billeder/2010-05-26_205437_088051.pdf
This gets very deep into the Volvo electronic system and talks some about E000 and E001 codes. Also talks about trouble shooting process for CANbus. No silver bullets here, but some solid information. I found this while investigating my own CAN bus problems on the same model.
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
