Did you know? 🤔
question on changing out control arm
2001 - 2007 XC-70
amblerman
Year and Model: 1999 s70
Has thanked: 1 time
Been thanked: 35 times
United States of America
amblerman
Re: question on changing out control arm
Post by amblerman » Wed Sep 18, 2019 1:42 pm
xHeart wrote:
Wed Sep 18, 2019 12:38 pm
Raising on jack stand is first step to ensuring personal safety.
That will definitely be done. I have jack stands I am comfortable with. My question about safety was about anything involved with the LCA job that might cause some unique experience over the same job on my s70.
There seems to be the potential for putting components under tension (with straps or giant levers) than compared to my s70.
-A
Antoine240bk
Year and Model: XC70 2.5T-2006
Has thanked: 10 times
Been thanked: 14 times
France
Antoine240bk
Post by Antoine240bk » Wed Sep 18, 2019 2:18 pm
Wow.. lower subframe to get a bolt out.. that is really a terrible design for something that will definitely be serviced (LCA).
Maybe that's why all the videos I've watched are done on driver's side. :D
I'm assuming (but have to ask) if the bolt has to come all the way out or does it unscrew enough to get the LCA off. I'm assuming it has to since you mention that. and by "strech screws" you're talking about BOTH the driveshaft to knuckle and the subframe bolts.
-A
That's what i thought too! :)
You'll be fine with a 15mm offset spanner to do this job near the subframe.
Yes it does unscrew enough to get the LCA off. I changed out three of the four screws with new and the big rear one as well.
They have different length, on the front these are shorter.
I always use new screws when i can.
Screws on both driveshaft to knuckle are meant to be stretch for one use.
Volvo XC70 2.5 T AWD P2 BVA B5254T2 12/2005 Four-C EX : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -Gpl - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
oragex
Year and Model: S60 2003
Has thanked: 95 times
Been thanked: 265 times
Canada
oragex
Post by oragex » Wed Sep 18, 2019 2:59 pm
On mine I just jacked the engine/transmission about 1inch on each side. Didn't disconnect anything but you dont want to force too much either - really just enough to place the spanner or ratchet. Ratchet wise, i'd go with the 1/2, those 15mm may be too much for a 3/8 No need to preload anything imo, but placing the bj back is difficult because the lca bushings are new and very stiff. May try to pull the arm down with a strap attached to the jack stand. I prefer rather disconnecting the strut bolts - careful not to stretch the CV joint
Has thanked: 315 times
Been thanked: 969 times
Trinidad & Tobago
Post by abscate » Wed Sep 18, 2019 3:50 pm
Volvo says to use a new bolt on the axle shaft but the torque is well below the stretch point of an M8 bolt, I think its only 50 Nm spec.
I always use a new one, though. Its a major hassle if it gets loose - all sorts of ABS errors and speed errors and crap like that.
Link To Volvo Glossary
xHeart
Year and Model: 13XC90/01V70X/97N854
Has thanked: 20 times
Been thanked: 39 times
xHeart
Post by xHeart » Thu Sep 19, 2019 10:00 am
-A
Placing a bottle jack (3-ton) under the rear part of subframe for support using a wooden block as buffer -- movable. Strap method is Volvo recommended, indeed safer than giant lever -- use a better grade strap.
The long bolts are hard to torque due to their location - snug and then 45º has worked for me.
Golden Retriever | 2014D VIDA DiCE | 2013A XC90 +144mi/231km | 2001 V70XC 1st Owner +196mi/ +315km | 1997 Volvo 850 NA 1st Owner +180mi/ +289km
Past: German Shepherd | 1989 Volvo 740 GL | 1979 Volvo 240
amblerman
Has thanked: 1 time
amblerman
Post by amblerman » Mon Sep 23, 2019 8:45 am
Thanks for everyone's help and suggestions.
I helped forum member Mr. Detail with his car this saturday. We only got one side done because of the amount of time we were able to devote to the job but mostly everything went well.
Before doing this job I had trouble visualizing why the control arm had to be pulled down with such force.
on my 1999 s70, the control arms rotate freely. But on the later cars like this 2003 V70, they can't rotate downwards freely at all. Just a different design. It does take a bit of force to lower them.
We changed out his front bearing, sway bar links and control arms.
What went well:
None of the fasteners were stuck or seized
strap method worked just fine.
protected CV joint so no damage to outer boots.
everything went back in fine.
What didn't go well
discovered both inner CV boots torn
discovered both front brake lines need to be replaced.
when attaching the steering knuckle to strut, we had a lot of difficulty getting second bolt through. We started with top bolt but the bottom hole proved impossible to align. When we started over and put bottom bolt in first, the top hole was easy to align.
Thanks again
<edited for spelling>
Trinidad & Tobago
Post by abscate » Mon Sep 23, 2019 10:18 am
Car safety Police here. That is a no on jack stands on unstable ground, please.
You could work that with a stiff piece of wood or metal in good condition for all four bearing surfaces of the jack stand.
Screen Shot 2019-09-23 at 12.14.15 PM.png (1.58 MiB) Viewed 23 times
amblerman
Has thanked: 1 time
amblerman
Post by amblerman » Mon Sep 23, 2019 1:00 pm
That photo scares me. How could that even work? I can't imagine the ground being hard enough to support that as it is.
We were on a nice driveway and all surfaces were solid.
Trinidad & Tobago
Post by abscate » Mon Sep 23, 2019 1:42 pm
That was Antoine's bad.
Merci, mon ami....
Liberte, Equalite, Fraternite, and Jackstande on Cemente
oragex
Canada
oragex
Post by oragex » Mon Sep 23, 2019 1:48 pm
Jackstands on grass ? That looks scarry. The jack may even incline and flip on the side being tall
