Did you know? 🤔
Misaligned Camshaft Timing Mark
2001 - 2007 XC-70
XCMat
Year and Model: V70XC 2002
Has thanked: 2 times
Been thanked: 0
United States of America
XCMat
Post by XCMat » Mon Nov 25, 2019 10:33 am
While replacing the timing belt on my '02 V70 XC my initial pre-removal inspection of the belt showed the exhaust cam was off by more than one notch clockwise. The intake cam and the crankshaft alignment were spot-on and the car has been running fine for a long time. A worn or stretched belt seems like it would have caused the cam to move off alignment in a counter clockwise direction.
Exhaust Cam Alignment Begin.jpg (14.25 KiB) Viewed 95 times
Is there a common cause that would induce camshaft misalignment without generating any codes or performance issues? Should I rotate the exhaust cam so everything lines up better when the new belt is installed?
oragex
Year and Model: S60 2003
Has thanked: 94 times
Been thanked: 242 times
Canada
oragex
Re: Misaligned Camshaft Timing Mark
Post by oragex » Mon Nov 25, 2019 12:10 pm
Don't think a belt would 'stretch' at least not an eye-measurable amount. If only the exhaust cam is misaligned, I would guess the person who replaced the belt had the ex cam move off mark. Also careful with the mark on the crank pulley and block - crank has two teeth marked, block has a hard to see bump - the bump will stay between the two teeth, more towards the front one
These users thanked the author oragex for the post:
XCMat
XCMat
Been thanked: 0
XCMat
Post by XCMat » Mon Nov 25, 2019 2:22 pm
Thanks Oragex. Here's a shot of the crankshaft. The alignment is definitely biased towards the front groove, just as you said. I'll tweak the exhaust cam a little counter clockwise and call it good!
oragex
Canada
oragex
Post by oragex » Mon Nov 25, 2019 5:43 pm
I think I was wrong about the crank mark on the block, would rather be closer to the rear tooth with notch. Notice the bump 'mark' is sitting at the left lower 'corner' of that U shaped piece of metal on the block - at least on my car. I could feel it by touching. Given the camera angle, it looks pretty much like on your car
A better picture of the block mark for the crank pulley - blue line
Has thanked: 0
Been thanked: 126 times
Post by cn90 » Mon Nov 25, 2019 6:13 pm
The CRANK marks, this is exactly how they should line up...
These users thanked the author cn90 for the post (total 2):
XCMatabscate
oragex
Canada
oragex
Post by oragex » Tue Nov 26, 2019 6:15 am
Great pic
XCMat
Been thanked: 0
XCMat
Post by XCMat » Tue Nov 26, 2019 8:43 am
Thank CRANK marks, this is exactly how they should line up...
That's the money shot right there... I'll have to take a closer look again now that I have the belt off. Thanks!
