IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
Suspension noise Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
d0nahuge
Year and Model: 2007 Volvo S60 2.5t
Has thanked: 0
Been thanked: 0
United States of America
d0nahuge
Post by d0nahuge » Tue Mar 03, 2020 7:41 pm
I own a 2007 Volvo S60 2.5t, and my front passenger side wheel is making a clunking and squeaking noise when hitting bumps. I will attach a video with the noise at the end of the post. Not sure what is causing this noise, the noise is loud and happens mostly in neighborhoods (slower speeds). The noise can only be heard when bumps are hit. The tie rods are new and I made sure they were installed correctly. I inspected the suspension on the front passenger side and all the parts dont have any play and theres no grease anywhere, bushings all look good. I might have missed something when I inspected the suspension myself. Let me know what you think the noise could be. My guess is shocks. https://youtu.be/HNVrkdVl1J8
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 55 times
Been thanked: 81 times
- Pete -
Re: Suspension noise
Post by - Pete - » Tue Mar 03, 2020 8:48 pm
I honestly don't hear a squeaking noise, more of a clattering. Something is definitely amiss.
I'd say most likely sway bar end links (1 per side, but do both if replacing just 1), passenger front spring seat and/or top mount plate. Bad sway bar bushings could also be drumming up some noise.
Could also be shocks, but I doubt it. I'd grab your sway bar end links & see if they wiggle easily or have play on either end. Do this with the front end completely in the air or on the ground, not just the left or right side jacked up. The ball joints on either end of each end link take a beating & eventually go out of round & result in a racket.
Speaking of ball joints, have you noticed any steering abnormalities? If so, could be the ball joint in your front control arm and/or control arm bushings.
2001 V70XC 146k
2004 V70 AWD 141k
2004 V70R M66 144k
2004 XC70 287k
2006 XC70 155k Sold
oragex
Year and Model: S60 2003
Has thanked: 95 times
Been thanked: 266 times
Canada
oragex
Post by oragex » Tue Mar 03, 2020 10:51 pm
How many miles ? Pete has already told it all, I would add the brands used is essential on these cars. Have a search on google like "volvo s60 best brands parts forum", youll find plenty of topics. End links and spring seats are common items, try to conserve your old strut mounts as newer ones are doubtful quality. My guess would be the spring seats, as the end links make rather a clunk noise. For the end links, grab them by hand and give a Solid shake near both the upper ans the lower ends. Again, if bringing it to a local garage, bring your own parts frrom Fcpeuro or alike.
d0nahuge
Has thanked: 0
Been thanked: 0
d0nahuge
Post by d0nahuge » Wed Mar 04, 2020 6:17 am
My car has 80k miles, and I bought the car with around 74k miles. I would assume all the suspension parts are from the factory except the tie rods which were replaced recently. I checked the sway bar links for play and they did not move. I only had the passenger side jacked up when testing, but like Pete said, I should put the cars front end up completely off the ground then test. There is a little bit of cracking on the sway bar bushings, which could contribute to the noise.
d0nahuge
Has thanked: 0
Been thanked: 0
d0nahuge
Post by d0nahuge » Wed Mar 04, 2020 6:26 am
I have not seen any steering abnormalities. I have seen videos online showing noise when turning the wheel without moving which I have not seen. I tested the ball joints and there was no play. I'll do a redo of the sway bar link test with the whole front side up, I only had one side up when testing.
- Pete -
- Pete -
Post by - Pete - » Wed Mar 04, 2020 7:40 am
You will not get an accurate idea if the end links are bad with only one side of the car off the ground. Has to be entire front/rear or entire car off the ground, not left or right.
With only one side in the air the sway bar is putting tension on the end link that is in the air so it will “feel tight”.
I personally wouldn’t worry about the sway bar bushings. They are captive to the sway bar and essentially you must replace the entire bar to lay waste to worn out bushings. Grease em up real good and forget about em.
2001 V70XC 146k
2004 V70 AWD 141k
2004 V70R M66 144k
2004 XC70 287k
2006 XC70 155k Sold
oragex
Canada
oragex
Post by oragex » Wed Mar 04, 2020 7:41 am
80K is quite low miles. Are the local roads very poor ?
d0nahuge
Has thanked: 0
Been thanked: 0
d0nahuge
Post by d0nahuge » Wed Mar 04, 2020 9:22 am
Yeah, there are a lot of pot holes around here. Not sure if the previous owner had major damage from an accident that caused any suspension damage.
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 29 times
Been thanked: 69 times
MoVolvos
Post by MoVolvos » Wed Mar 04, 2020 9:36 am
Could be a strut bushing?
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
d0nahuge
Has thanked: 0
Been thanked: 0
d0nahuge
Post by d0nahuge » Wed Mar 04, 2020 2:39 pm
I lifted my car with both sides up and looked at the suspension again. I did not see any play with the sway bar link. Should I go ahead and order some new sway bar links? This user posted a video with the exact same noise I heard and they found out it was the sway bar link (viewtopic.php?f=10&t=87890).
