Engine Mounts
- hmsky83
- Year and Model: 2001 S60 & 2002 S60
- Has thanked: 6 times
Engine Mounts
How do I diagnose each of these mounts ? I've already changed 3 out of the 5. But still haven't solved the issue.
- Front & Back Lower Mounts
- thumbnail_25475.jpg (5.39 KiB) Viewed 157 times
- Passenger Side Mount
- thumbnail_32124.jpg (7.61 KiB) Viewed 157 times
- Upper Mount
- thumbnail_16084.jpg (6.59 KiB) Viewed 157 times
- Transmission Mount
- fullsize_16086.jpg (34.93 KiB) Viewed 157 times
2001 Volvo S60 2.4T
2002 Volvo S60
2005 Chevy Avalanche
2002 Volvo S60
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 325 times
Vibrations or shifting problems ? The third picture is the upgraded one, should be fine. Second one see vid. Last one doesn't really go that bad because it can't move too much - but may start knocking a bit
- hmsky83
I replaced the upper, side and transmission mounts. The only two, I didn't change are the first picture (front and back lower mounts).
Here's the issue... when the car is parked and turned off if I push the car forwards and backwards, I hear a squealing sound. Also the motor jumps up and down when I'm pushing the car forwards and backwards. Is that normal ??
2001 Volvo S60 2.4T
2002 Volvo S60
2002 Volvo S60
- ndphotonl
- Year and Model: 2001 S80 2.4T
- Has thanked: 27 times
- Been thanked: 33 times
My recommendation is to change them all if your car is older. I changed them all and upgraded 2 out of 5 with polyurethane versions (optional off course). If you have shifting issues, change the transmission mount. Shifting was way better after replacing it.
Polyurethane top mount (SuperPro)
Volvo S80 2.4T Polyurethane Upper Engine Mount completed by Andy Ramdin, on Flickr
Polyurethane transmission mount vs old knackered one
Volvo S80 2.4T New vs Old Gearbox mount by Andy Ramdin, on Flickr
Volvo S80 2.4T PU Gearbox mount by Andy Ramdin, on Flickr
Front, back and side mounts
Volvo S80 2.4T Engine Mounts by Andy Ramdin, on Flickr
New vs old side mount
Old vs new mount
Old vs new mount
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
FlickR images
- 24 Replies
- 3957 Views
Last post by 98v70dad
- 11 Replies
- 2193 Views
Last post by xHeart
- 409 Views
Last post by BEJinFbk
- 675 Views
- 586 Views
Last post by bmdubya1198
