IPD sale XeMODeX - Experts in Volvo Electronics Volvo modules repair and programming
Please use the MVS Amazon link when you buy anything at all! It helps this site. Thanks very much!
2002 Volvo S60 loud Squeaking engine noise
2001 - 2007 XC-70
marshg2k
Year and Model: s60 2002
Post by marshg2k »
Hey Guys,
I have an otherwise excellent 2002 Volvo S60 with a strange but loud squeaking engine noise. The car had an oil leak (From the Crankshaft VVT solenoid gasket) that was fixed. But still there is this loud squeaking sound but only happens when the engine warms up.
The sound is coming from the pulleys (crankshaft, timing belt etc) end of the engine. I checked all the belts and they seem fine with correct tensions and none of the pulleys seems off.
You can listen to the engine sound while cold and after warming up. The car still drives fine even with the noise.
Thanks
25813354-F094-471C-B2AB-73EA1DB65151.MOV
Engine sound when cold.. no squeaking noise
(39.93 MiB) Downloaded 34 times
5C824468-21AE-4A20-BFB4-95F6863B68A9.MOV
Engine noise after warming up
(67.75 MiB) Downloaded 29 times
Been thanked: 162 times
Re: 2002 Volvo S60 loud Squeaking engine noise
Post by cn90 »
- Remove the belt, spin ALL the pulleys (belt pulley, alternator pulley etc.).
- I bet you the pulley grease has dried up.
What is the mileage and service history? Were the pulleys/belt ever replaced?
marshg2k
Post by marshg2k »
I have 163k miles the timing belt, pulleys , water pump , tensioner were replaced @ 100k. Been doing fine. How do I grease the pulleys again?
Post by cn90 »
At 163K, get new Conti serp belt and INA pulley. I posted PN etc in this forum.
PS: regrease pulley only if you are short of budget. Search for the post I made on bimmerfest E39 forum...
jonesg
Has thanked: 2 times
Been thanked: 43 times
Post by jonesg »
marshg2k wrote: Tue Sep 08, 2020 4:38 pm Hey Guys,
Thanks
Have you run the engine without the acc belt?
marshg2k
Post by marshg2k »
Nope .. I have not done this. I was thinking of doing it so thanks for your comment. Is it possible after the oil leak the ACC belt could somehow be slipping and the reason for the noise. I know the timing belt has "teeth" so it would not slip and if it did there would be a performance issue with the car and there is not. But the ACC belt has no "teeth" or "grooves" it is a flat belt. Could it be slipping?
darrylrobert
Year and Model: 2001 v70xc M58
Has thanked: 3 times
Been thanked: 20 times
Post by darrylrobert »
remove the serp belt to make sure its not the timing belt making the noise. or you can get a belt lube and rub it on the belts..its probably your serp belt, i think my serp belt is noisy also when hot.
2001 XC70 factory M58
2002 XC70 auto (parts car)
marshg2k
Post by marshg2k »
i removed the serp belt but the issue is still there. So its not the serp belt, idler pulley, alternator or the a/c compressor. so i am left with the camshaft pulley, the crankshaft pulley, the timing belt and the tensioner. How do I lubricate the pullies? That seems like the next logical step.
jonesg
Post by jonesg »
its safer to swap the pulley and tensioner out, they're cheap enough.
It could be water pump pulley too or the tensioner might be over tightened and distorted.
Some guys mention spraying water on pullies to find the squeaky wheel, I'd rather just swap the lot out.
any noise or potential problem in that belt area can kill the engine, even at idle speed.
oragex
Year and Model: S60 2003
Has thanked: 100 times
Been thanked: 302 times
Post by oragex »
How is the PCV test ? Does the sound change if you pull the dipstick or remove the oil filler cap ?
Do you know which parts were used for the timing belt at 100k ? Was the water pump replaced ? I would not drive the car until finding the culprit, a cheap water pump will seize all of a sudden and the engine will be gone
