Marking "Topic Solved" is functional again. It's the green check next to your post. BTW, please do use this when your question is answered and verified. Thanks!
MVS-Amazon link helps MVS!
2.5T AWD - got a bearing sound/ whining noise underneath Topic is solved
2001 - 2007 XC-70
greffel
Year and Model: 2003 S60
Has thanked: 3 times
Been thanked: 3 times
Post by greffel »
Hello
My car is a S60 2.5T AWD my 2003 and I got a bearing sound/ whining noise from under the car.
Read that the angle gear could be the source or a support bearing.
To isolate the source during acceleration I put just a little bit of break pressure on just enough to get the break lights to turn on.
Immediately the sound disappears. From my understanding the AWD disengages when the break is pressed.
I don't have any time to look in to this until the weekend so I pulled the fuse to the Haldex unit and the sound is gone.
What is the most possible source of this bearing sound. Support bearing to the cardan shaft?
jonesg
Year and Model: 2004 V70
Has thanked: 2 times
Been thanked: 43 times
Re: 2.5T AWD - got a bearing sound/ whining noise underneath
Post by jonesg »
greffel wrote: Tue Nov 03, 2020 10:47 am Hello
I'd say its the Haldex.
I pulled my haldex fuse 3 yrs ago, whine is gone.
greffel
Post by greffel »
But I guess i could be the ange gear or a bearing.
Blacklab467
Year and Model: 2003 xc 70
Has thanked: 5 times
Been thanked: 15 times
Post by Blacklab467 »
The propshaft turns all the time with the transmission through the bevel gear. If the whining sound is coming from the front around the floor area it is likely the collar sleeve spinning on the bevel gear input shaft. Pulling the haldex fuse in the back may stop the whining if the splines are just starting to go. When the rear Haldex demands torque through the propshaft for instance in a low traction situation, torque will be transmitted through the propshaft and the Haldex the turn the rear differential.
The U-joint or support bearing will be fine, it turns all the time as mentioned earlier. If the noise goes away when you have the Haldex fuse pulled, and this is counterintuitive, its likely the Bevel gear and not the Haldex unit.
Its about an hour and a half job to remove the BG and check the collar sleeve and input shaft splines, this will be where the problem most likely lies.
I recently went through all this on my 03 xc70 and did a lengthy write up that may help you, by the way how many Kms on the car?
2003 XC 70, 2007 Duramax LBZ.
greffel
Post by greffel »
I think it's a little bit more then 1.5h with my skills :)
Do I need to remove the angle gear from the car to inspect ?
The car has 18500km (115 000 miles)
So if I'm lucky its just the collar sleeve.
Will read upp on you guide.
Blacklab467
I would have to hear the noise you are talking about to be a little more sure about the diagnosis. Any chance you could record it on a short drive and upload the clip?
You will need to remove the angle gear to inspect it, and there won't be any getting lucky with just a collar sleeve, that sleeve tends to wear out in unison with the BG input shaft sleeve. If its making the noise that you describe, I'd be about 99% sure on my diagnosis. You're likely going to need a new or good used Bevel Gear and a New Collar Sleeve, or you could go with the welded setup as described in my post that I PM'ed you.
greg850r
Year and Model: a long list
Been thanked: 11 times
Post by greg850r »
Hey guys, look at the pics in this thread. I put in a new collar, said a prayer and have yet to hear back from it. I did not think it would last and figured on doing the weld fix. My wife has put a lot of miles on it since and reports no issues. Apparently there was enough left of the splines on the shaft for a new collar not to strip. She does drive it easy...
https://www.matthewsvolvosite.com/forum ... 37#p522637
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4
24' 454 Challenger
07 Softail Custom
02 Sportster Custom
Parts cars not included
Has thanked: 443 times
Been thanked: 1339 times
greg850r wrote: Wed Nov 04, 2020 5:46 pm Hey guys, look at the pics in this thread. I put in a new collar, said a prayer and have yet to hear back from it. I did not think it would last and figured on doing the weld fix. My wife has put a lot of miles on it since and reports no issues. Apparently there was enough left of the splines on the shaft for a new collar not to strip. She does drive it easy...
Blessed are the wives who drive our cars easy - so we can have T5s with 260,000 miles on the original clutches after kid hauling.
Link To Volvo Glossary
greffel
Post by greffel »
Hello
Jacked up the car and did the inspection.
1. Tried my best to feel any play in the propulsion shaft, but found none.
2. Rotated the right front wheel and tried to hold the propulsion shaft, every thing felt solid :)
3. Rotated the front wheel faster, resulted in the sound in the clip. Doesn't sound that great?
4. Listened for sounds from the angle gear in front to back of the Haldex and the sound comes front the angle gear
Almost sounds like there is no oil in the gear, there was oil on the outside from leakage
Angle gear sound:
greffel
Post by greffel »
Removed the fill plug and put a stick down the fill hole to check if there was oil in it.
It has the right amount of oil and the oil is not black its actually pretty clear and good looking
