2.5T AWD - got a bearing sound/ whining noise underneath Topic is solved
- Year and Model: 2003 xc 70
- Has thanked: 14 times
- Been thanked: 25 times
Re: 2.5T AWD - got a bearing sound/ whining noise underneath
You're best bet now is to procure a new propshaft or a good used one from the auto wreckers, this is most definitely you're problem!
2003 XC 70, 2007 Duramax LBZ.
The bearing may or may not be ok, It's the rubber support that is the problem and causing the noise when driving. Start sourcing out a replacement propshaft. You cannot service or replace that single support or bearing separately unfortunately.
I suppose you could try to "shim" it to center the bearing for the purposes of troubleshooting. There's no question that the rubber in the bearing support is worn out though. If you could source out another propshaft that would save you the trouble of installing it and then having to remove it again to replace.
- - Pete -
- Has thanked: 74 times
- Been thanked: 123 times
Time to get ahold of Colorado Driveshaft, unless you can/are able to pull one from a scrap yard car.
2001 V70XC 167k
2004 V70 AWD 147k
2004 V70R M66 146k
2004 XC70 299k
2006 XC70 155k Sold
2004 V70 AWD 147k
2004 V70R M66 146k
2004 XC70 299k
2006 XC70 155k Sold
- Year and Model: 2.0/2.4/3.2
- Has thanked: 32 times
- Been thanked: 56 times
Golden Retriever | 2014D VIDA DiCE | 2020 V60CC | 2013A XC90 +150mi/241km | 2001 V70XC +200mi/322km
Past: German Shepherd | 1997 Volvo 854 | 1989 Volvo 740 GL | 1979 Volvo 240
- - Pete -
You will want to find out the country of manufacture on all the bits involved with IPD’s driveshaft. There’s 2 CVJ’s & a bearing in the middle. You don’t want Chinesium on either end, nor in the middle here.
Colorado Driveshaft has a remarkable reputation with P2 driveshafts. In fact, I can’t recall a single instance where a company OTHER than Colorado DS was recommended.
I have personally purchased several F/R CVJ’s from them and they/their products are superior & far undercut factory prices.
To reiterate, I don’t know what IPD uses for their CVJ’s or hanger bearing, but you will need to find out.
2001 V70XC 167k
2004 V70 AWD 147k
2004 V70R M66 146k
2004 XC70 299k
2006 XC70 155k Sold
2004 V70 AWD 147k
2004 V70R M66 146k
2004 XC70 299k
2006 XC70 155k Sold
- Year and Model: 2003 S60
- Been thanked: 3 times
Happy New Year !!
The bearing sound has been localized and now I need some advice what to do.
Removed the angel gear from car trying to isolate the sound and this is what I found.
The bearings are really rough and quite a lot of binding:
So I decided to take it apart...
Status of the AG looks to be quite good:
1. Half worn splines ( might do the weld mod on it..)
2. The crown wheel and pinion gear are in good shape
3. Bearings on crown wheel axle seems really smooth (type 32010 X/Q)
4. But the pinion bearings sounds like this:
I'm thinking of just ordering the bearings for the pinion, clean everything and put it together. Sounds good ??
Lets see a picture of the input splines.
