So I got the first right front subframe bushing out using the drilling out of the plastic method. It came out real easy in about 5 minutes. I wrongfully assumed that I'd be able to use the jack as a press to get the new one, it's went about a half inch and then stopped. I did clean out the bore with emery cloth and put a small amount or wheel bearing grease to help it slide in but no luck.
Does anyone have any tips, tricks, or videos to get these in?
Thanks!
Any advise on how to install subframe bushings?
- Year and Model: 2003 xc 70
- Has thanked: 12 times
- Been thanked: 21 times
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 324 times
edited, topic solved in a different tread
Thanks, I went out last night and developed a real easy method of installing these. Will post pictures after I get the other two in this morning.
2003 XC 70, 2007 Duramax LBZ.
- Mike Langlois
- Year and Model: 2002 V70 & V70 XC
- Has thanked: 28 times
- Been thanked: 4 times
I just did this and did it wrong the first time; Thank God for FCP. I built bushing pullers and bushing install tools, that I will be happy to loan to you. I did not get them seated properly and the weight of the car will not seat them. Make sure that they are lined up (there are marks on them) and make sure they are fully installed and flush. I did the job twice and that was no fun. PM me or call at 714-290-9704 if you would like to borrow the tools.
Yours,
Manic Mike
Yours,
Manic Mike
Thanks Mike, I got it figured out done and posted the topic on the forum with some pictures. I had an easy time with mine once I fashioned a way to pull them in and seat them. You're right though about getting them started straight! Thanks for the offer on the tools.
- 25 Replies
- 5157 Views
Last post by brunocerous
- 1177 Views
Last post by theWIFES_S70
- 859 Views
Last post by smacknab
- 10 Replies
- 1628 Views
Last post by ecbsykes
- 270 Views
Last post by oragex
