12V source for testing Haldex pump 30783079 Topic is solved
Has thanked: 135 times
Been thanked: 372 times
Re: 12V source for testing Haldex pump
Zero life in the pump once I got it off the car, same as the test when it was on.
I have a new one coming though I was chicken to go with Dorman, shelled out for the Volvo one. I'll probably put a Dorman on our S60, it needs one too. But that's for like spring time - one prop shaft per quarter please!
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6 :shock: 130k
Blacklab467
Year and Model: 2003 xc 70
Has thanked: 12 times
Been thanked: 21 times
Post by Blacklab467 »
You can't go wrong with the Volvo pump, I'll probably find myself wishing I had done the same at some point but so far so good. You may elect to try and clean and rebuild your old one, mine was mostly full of brush dust and oily goo, I thought I could clean up the armature and put some new brushes and bearings in it and keep it for a spare but then broke a plastic piece that I think holds the brushes so I threw it out. I suspect that the only cause of failure of it was being dirty and gummed up.
2003 XC 70, 2007 Duramax LBZ.
Blacklab467
I was hoping to get at least a couple years out of the Dorman but it died this weekend! 6 months old. New Volvo one is on order and another filter and bottle of fluid.
Has thanked: 457 times
Been thanked: 1360 times
Blacklab467 wrote: Sun Jan 03, 2021 1:59 pm I was hoping to get at least a couple years out of the Dorman but it died this weekend! 6 months old. New Volvo one is on order and another filter and bottle of fluid.
Thanks for the follow up, you just saved someone a lot Of hassle here.
Can you guys post the Volvo part number for this to make it searchable, please?
On edit, found it
https://www.fcpeuro.com/products/volvo- ... wE#fitment
Link To Volvo Glossary
Volvo AOC Haldex Oil Pump Kit - Genuine Volvo 30783079
This kit includes pump, installation screws, and the large nut for the oscillation damper.
Order Volvo-branded Haldex oil and the filter separately.
Or this kit has all three: https://www.fcpeuro.com/products/volvo- ... ervicekit1
'96 855 NA, 145k
'06 S60 R, 167k
'07 XC70, 170k
