The spring seat should be the same for S70 and S60, but the strut bearing plate is different, S60 has rounded plate, S70/850 has a square plate. However those in the link are very low quality and may not last long enough. Someone bough recently a cheap Lemforder bearing plate, started making noise right from the start and the steering may also be hard to turn because more than half the weight of the car is resting on these two front strut bearingsMoVolvos wrote: ↑Wed Dec 30, 2020 2:52 am
Get these and save up for a pair of struts. At least if you break them you can have them replaced free of charge till you are able to buy new struts.
https://www.1aauto.com/volvo-850-c70-s7 ... 06596/2001
replacing front struts again
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 324 times
Re: replacing front struts again
- Has thanked: 135 times
- Been thanked: 372 times
Good advice overall by most people in this thread but ugh don't buy these you will just create work for yourself! The spring seats need to be Sachs brand, that's what Volvo sells and they last the longest.MoVolvos wrote: ↑Wed Dec 30, 2020 2:52 am *
If you buy a set of lifetime warranty seats and bearings a bad strut will break them. When you go to the junk yard you won't know how long the seats and bearing will last. Then there is the DYI labor involved.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
130k
'96 855 NA, 145k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
- MoVolvos
- Year and Model: 03S80T6~08C30T5
- Has thanked: 52 times
- Been thanked: 110 times
If Sach are OE Volvo then it's FCP.erikv11 wrote: ↑Wed Dec 30, 2020 10:02 amGood advice overall by most people in this thread but ugh don't buy these you will just create work for yourself! The spring seats need to be Sachs brand, that's what Volvo sells and they last the longest.MoVolvos wrote: ↑Wed Dec 30, 2020 2:52 am *
2003 S80 T6
2008 C30 T5
2003 S80 T6
2008 C30 T5
- Year and Model: 2003 xc 70
- Has thanked: 12 times
- Been thanked: 21 times
I just installed OEM Volvo XC90 seats in my car......the difference is amazing. I'd say get a set of OEM struts from the wreckers, white label, and a new set of OEM seats, they're about 40 bucks, and find some good OEM links. I've learned the hard way not to bother with anything aftermarket in the front end for a variety of reasons.
2003 XC 70, 2007 Duramax LBZ.
- ndphotonl
- Year and Model: 2001 S80 2.4T
- Has thanked: 27 times
- Been thanked: 33 times
I disagree, I chose to replace the old struts on my S80 with Bilstein B4 (front & back) and I absolutely love them (and can highly recommend them). But everyone needs to decide for themselves off course. Complementary stuff was either Sachs or OEM (+Vogtland springs)
Volvo S80 2.4T Lowering Preparations Done! by Andy Ramdin, on Flickr
Volvo S80 2.4T Lowering Preparations by Andy Ramdin, on Flickr
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
FlickR images
- Year and Model: 99T5 ,99S70,2005V70
- Has thanked: 457 times
- Been thanked: 1360 times
Ugh. That’s an ugly piece of economics for that partSVO LOU wrote: ↑Wed Dec 30, 2020 7:26 am A few days ago I received a notification email from my local u-pull-it that they got an '01 xc70 in stock... Great, I needed a drivers side headlight for my son's car, so when I grabbed the headlight assy I noticed it had recently replaced front struts, needed those also. So with a different set of tools I went back yesterday to grabbed those two struts, drivers side was a 10-minute job including removing the wheel, awesome.
On the passenger side 4 wheel studs came off easily but that fifth one caused me to break 1/2" Craftsman AND Matco breaker bars (that I've had for over 20 years) and a factory volvo wheel wrench. With cheater bars, of course. I then enlisted a couple of young bucks nearby to help and they bent their 4-way lug wrench and broke a Craftsman ratchet on it.
Found another yard volunteer and he broke a 19mm socket on it, but with the use of my snap-on impact socket on his breaker bar/pipe combo, we got it to break free and I was able to quickly grab the strut that looked nearly new.
That used strut caused 5 broken tools.![]()
Link To Volvo Glossary
A couple minutes with a torch may have saved them all from breaking.
'96 855 NA, 145k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
130k
'96 855 NA, 145k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
- Year and Model: 01 V70 XC, 06 V70
- Has thanked: 16 times
I'm sure but I don't tend to carry one in my toolbag, had it been at home it would've been a different story.
On the plus side Ace hardware carries craftsman and swapped the bar right out for me, will have to find a Matco truck next.
Between lower control arms and struts/bearings these things are pretty time consuming but they drive so well.
Oh no doubt - actually I expect all yards forbid bringing in torches. As you said, had it been at home it would've been a different story.SVO LOU wrote: ↑Sat Jan 02, 2021 6:07 pmI'm sure but I don't tend to carry one in my toolbag, had it been at home it would've been a different story.
'96 855 NA, 145k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
130k
'96 855 NA, 145k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
- 13 Replies
- 2886 Views
Last post by SVO LOU
- 391 Views
Last post by nsjames
- 18 Replies
- 2029 Views
Last post by WhatAmIDoing
- 214 Views
Last post by erikv11
- 2398 Views
Last post by MadeInJapan
