Vida CEM swapping
volvofrank
Year and Model: S80 2007
Re: Vida CEM swapping
Post by volvofrank »
vtl wrote: 17 Feb 2023, 08:51 Try to add ground first.
Do you mean I should connect OBDII pin 4 and 5 to the Teensy GND?
The other schematic is basically the same as my "breadboard" version, that had the same result basically, found the first two bytes consistent but did not crack the code.
I can do live testing again after snowboarding next week ;-)
CEM partnumber is: 30765015
Nick73
Year and Model: S40 2011
Post by Nick73 »
does anyone have a Volvo cem configuration tool? can you share?
Nick73
Post by Nick73 »
duzi
Year and Model: S60
Has thanked: 18 times
Been thanked: 5 times
Post by duzi »
volvofrank wrote: 17 Feb 2023, 08:56
try lowering R1 and R2 resistor (2 or 3 kom)
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 175 times
Post by dikidera »
So to summarize my project.
Denso->Bosch. I will need the engine wiring harness and Bosch ECM. After that, a CEM re-flash of ROM and EEPROM OR a CEM from a donor 2.4T car, after which IMMO matching and then the modules will all fetch the signal configurations from the CEM? The question then remains of the other modules which spoke with the ECM and so forth.
I have compared the data from VIDA and a B5244T3 ECM differs from a B5244T5 ECM. Well the reasons are obvious, no dual VVt and more. So I basically have to focus on 2005+ S60s as donors, but then the head I have is Dual VVt so it needs be an ECM and engine code which works for me, so 2.5t. Then the question remains for the ETM, if now I also need a Bosch unit as I have a Magnetti Marelli which works.
I buy one part - sell one old, this will make the swap very cheap.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
dikidera wrote: 17 Feb 2023, 13:27 ... this will make the swap very cheap.
Few thousand euros later ;)
dikidera
Post by dikidera »
Should be far less money than that. I expect in Germany and USA to be expensive, but not in my country. Plus I still have something to sell from the car. Well it's still in planning phases. I will re-evaluate more.
vtl
Post by vtl »
dikidera wrote: 17 Feb 2023, 13:57 I expect in Germany and USA to be expensive
Nah, in US you pay $80 to private individual for his rear-ended or t-boned car, which is perfectly fine otherwise, and tow it with your truck.
dikidera
Post by dikidera »
Not what you get here. But at least the prices are somewhat bearable. We have a saying here. When you buy a car, you actually pay for it twice. And some, thrice.
It's true to this day.
T5Luke
Year and Model: S60 T5 2001
Has thanked: 11 times
Been thanked: 130 times
Post by T5Luke »
Just an easy question, what is the MY of your car (10th digit of your VIN YV1...) ?
