95-98 P80: 1. Pending parts lot, 2. 98% m56 kit $400- Antlers,Oklahoma
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
Two individual sales:
1. Pending parts lot update
2. 98% complete M56 kit (somehow contains the required third pedal hardware, but missing the third pedal.) Removed from 98 v70 w/ NA engine.
Pricing:
1. Pending parts lot update.
2. Manual trans kit for $400
List of parts: pending update, stay tuned
1x MSD ignition coil
4x headlight wiper motor (3x p80, 1x 960)
1x pair headlight Wiper arm
1x pair c/s/v70 headlights (shiny reflective)
2x p80/p2 foglight sockets
1x s/v70 foglight
1x complete pair fender side marker lights & wiring
1x good functioning AbS module w/ screws
2x pair knock sensors
1x throttle body w/ ball socket arm
1x 700/940 radio
1x bundle p80 4x50 amplifier wiring
1x power steering line
1x p80 gray steering wheel
1x complete fuel rail w/ set of NA fuel injectors
1x complete set NA fuel injectors
2x motor mounts (far right+front or rear)
1x complete set subframe bushings
1x pair subframe bolts
1x intake gasket
1x coolant bottle
1x coolant bottle cap
1x power steering pump + orings
1x power steering pump reservoir
1x ignition Switch
1x pair 02 Sensors
1x AC compressor
1x alternator
1x Break Booster
1x complete PCV set
2x vacuum trees
1x heater core shroud
1x heater core hose firewall passthrough
1x pair brake hoses
2x radiator fan relays
1x bundle of relays, fuses (large 30A/50A), and switches
1x pair driver+front passenger window switches
1x red seat airbag piston clip
1x c/s/v70 middle console rear ashtray, woodgrain
1x c/s/v70 complete Set air vents
1x c/s/v70 climate control module
1x blower motor
1x c/s/v70 dash cluster w/ attached module
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
GreenVolvoGoldenDog
Year and Model: 2000 V70 XC
Has thanked: 9 times
Been thanked: 3 times
Post by GreenVolvoGoldenDog »
I fear I’m staring at my same fate if I keep buying Volvos.
The M56 kit I am PMing for. Give me a few moments to figure out how to physically do that here lol!
GLWTS!
E: 854 still available!
spool
sneeze
1994 Volvo 850 NA Sedan (2022–2024) (sold)
1998 Volvo S70 T5 FWD (2020–2024) (sold)
2000 Volvo V70 XC AWD (2025–∞)
CIK7
Post by CIK7 »
Sale updated with parts list.
Olegs855R
Year and Model: 1995 855 Turbo “R”
Has thanked: 6 times
Been thanked: 23 times
Post by Olegs855R »
Still have the M56 and associated parts minus the 3rd pedal?
CIK7
Post by CIK7 »
Olegs855R wrote: 09 Aug 2026, 17:45 Still have the M56 and associated parts minus the 3rd pedal?
I sure do.
Olegs855R
Post by Olegs855R »
I’m going to research it a little to figure out exactly what is needed and will get back to you very soon. I live in San Jose, California
Olegs855R
Post by Olegs855R »
I assume everything you have for the trans is included ie; shifter/cables, any wiring or speed sensors, whatever. Can’t possibly use the same axles as the auto box, right? Those included as well?
Better yet, what do you NOT have for the swap besides the 3rd pedal?
Thanks for taking the time.
CIK7
Post by CIK7 »
Olegs855R wrote: 10 Aug 2026, 07:10 I assume everything you have for the trans is included ie; shifter/cables, any wiring or speed sensors, whatever. Can’t possibly use the same axles as the auto box, right? Those included as well?
I apologize for the insanely delayed response. Been up to my head in bureaucratic garbage today.
I dont think I removed anything from the transmission that wasn't required for removal of the whole unit. Im sure everything except the third pedal is there. Axles are not included. Im pretty sure I read somewhere that someone THOUGHT the manual used different axles than the auto but im pretty sure someone corrected that assumption in the same or a different post. Go to the p80 section and click 'advanced search'. Type 'm56+ axle+' without the apostrophes. That should guide you to the correct answer.
Olegs855R
Post by Olegs855R »
OK, here’s the list
Transmission
Flywheel
Clutch pressure plate, disc, and throwout bearing
Clutch fork
Clutch master cylinder and slave cylinder
The hydraulic clutch line
Transmission mount and crossmember
Pedal assembly
Shift linkage cables
Shifter assembly, knob and boot
And I will check out the axle issue but let me know if you have all that stuff or what’s missing and we’ll go from there . Sound cool?
Olegs855R
Post by Olegs855R »
Oh yes, and the manual transmission ECU
And I apologize for taking us so long to get back to you
