It is possible it could crack if over-tightened. How soft is the lower hose? I have found that if you re-use hoses when changing radiators or any connection, they sometimes won't re-shape to the new connector and can bunch, stretch or just not shrink to the new connection.
PITA I know, but only way to find out is to drain the radiator and remove the bottom hose the check both sides of the union for issues.
- Has thanked: 1856 times
- Been thanked: 1717 times
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
*brunocerous wrote: ↑11 Feb 2023, 13:40 I found coolant weeping from Blue Steel’s lower radiator hose. I tried changing the worm-drive hose clamp with a new one, which slowed it, but there’s still a slight leak. I wonder if the replacement Nissens rad has a crack at the lower hose port.
If possible I always try to slice away the portion of any hose where the old hose clamp use to be. As long as the tension, due to the shorter length of hose is minimal it should be fine.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
I never have luck getting the rubber hoses to not leak. So I always end up buying silicone hoses. They seem to shape, seal, and reseal well.
Knows enough to be dangerous
- Has thanked: 1509 times
- Been thanked: 3827 times
Dr Oetiker to the Rescue
- Has thanked: 305 times
- Been thanked: 517 times
Yeah, the hose is probably too soft if you didn't replace it already. Time for a new one!
- ZionXIX
- Has thanked: 65 times
- Been thanked: 194 times
Is the 99+ dipstick constructed differently?
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 131 times
99+ upgrade? I like the dipstick on my 96 better. I haven't directly compared the two, however. I can't say exactly what's different between the two. The 96 is orange, and I think the 99 is red like what you show. I think the steel part is different somehow.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 112 times
The 99+ have two O-rings, which means the tube isnt full of condensation all winter
You have to replace the dipstick and tube as they are both different from the -98 version
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
454cid
I bought some brake pads I don't need immediately, because of price.... I found Akebono front pads on clearance at Rockauto and bought the last set. With shipping, and the spring retainers I spent about $21. The first set I bought, I spent triple that at FCP, and then used them on the S70 out of necessity, when I intended them for the 850.
I notice Akebono has two lines, "Euro" and "ProACT". The FCP pads I think are the Euro line, and the discount pads I just bought are the ProACT, but I'm not sure it's anything more than marketing.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
