Used oem behr.
I don't like to cheap out on my cars. I read over things 1000 times before I do it so I make sure it's right!
Will do! Certain trees are starting to change already! We've had some cold nights this week
- Gmstewart22
- Year and Model: 2000 v70 GLT, 850-T5
- Has thanked: 11 times
Replaced vac line to the wastegate. The old line was cracked and leaking vacuum /Wastegate not opening was getting engine light for what I presumed was a overboost code. Light went away after I fixed the line.
2000 v70 GLT
1997 v70 AWD lpt
1997 v70 AWD lpt "rally rig"
1995 850 T5
1997 v70 AWD lpt
1995 850 T5
- Has thanked: 1509 times
- Been thanked: 3827 times
Kayaking then a picnic lunch...
- Has thanked: 305 times
- Been thanked: 517 times
You know, the car might float better if you put the kayaks on the bottom...
- jvl
- Year and Model: 2006 V70 2.4D
- Has thanked: 20 times
- Been thanked: 8 times
Fixed a huuuuuuuuge vacuum leak today:
The vacuum hose that comes from the intake manifold towards a T-joint was completely torn into pieces and ripped.
Put in a temporary fix because I didn't have the correct hose. The car drives much better and FINALLY passed the glove test!!
Super excited about this improvement, but still have to put in the correct hose: this temporary one will probably not holdup long.
Anyone know the correct diameters for these hoses? The hose from manifold to check valve is really thin, the hose from check valve towards T junction is thicker.
1999 V70XC - Sold at 250K miles
2006 V70 2.4D - bought at 190k miles and going strong
Check my cold idle thread from earlier this year, see if I snapped a pic of the hoses I used to replace same
If you can’t find searching with V70T5m56 in search string it is linked in my maintenance repair thread for 1999 T5 nautic blue
Found it. Hose sizes are on a piece of paper written in sharpie , second page thread
viewtopic.php?f=1&t=84552&start=10
- jvl
My hose was split in the exact same way as the one in your picture!
Great sketch, you have obtained many karma points for sharing that. Thanks!
Oh and, great viking helmet too. We just have orange silly hats....
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Driving down some country roads this morning. Ran over what I believe was a walnut. The pop was so loud I thought the turbo blew up or I was shot at. Made me jump a good 3 inches out of my seat.
Knows enough to be dangerous
That hose in my R was in the exact same condition. I can only imagine the amount of Bastard owners with that same problem!abscate wrote: ↑30 Sep 2018, 10:16 Check my cold idle thread from earlier this year, see if I snapped a pic of the hoses I used to replace same
- 850 LPT
- Year and Model: 96' 850
- Has thanked: 332 times
- Been thanked: 243 times
Put fancy wheels on my 850.
Apparently, the car doesn't like them, because immediately after I got sputtering and coughing like crazy. CEL came on with multiple misfire codes.
I never checked after I bought the car in the spring, but I pulled the cap and rotor and they are the worse ones I have ever seen. Same goes for the plugs.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
