- Has thanked: 1507 times
- Been thanked: 3825 times
I’ve got some H7 connector looms I can send. I’ll reach you on the resistance channel of American Patriots fighting for Canadian Freedom, aka , “you’ve got 50 States, don’t cross the 49th”
- Has thanked: 1854 times
- Been thanked: 1714 times
I'm hoping the pictures are in reverse order unless you are going for the 'patinated' look?
Great job, you will now have a line up of MVS'ers looking for you to do the same for their cars!
I ordered a dozen ceramic H7 pigtails from Alibaba last night. They were $12 CDN with priority shipping!
I do like using the OE parts though, but I wonder if they are as brittle as the ones I saw yesterday. Every light had one bulb (usually the outer one) that was just crumpling. Maybe worth taking time to clean and tighten the connectors.
- P80GLT
- Has thanked: 154 times
- Been thanked: 176 times
The plastic liners have factory overspray on them and applying Chemical Guys Bare bones would not enhance it therefore no point in wasting money, plus it's way back in complete darkness so will never be seen once the wheels are on
Might be a bit expensive getting MVS'ers cars over here to clean the wheel liners
Drove KarlaKat long island to Albany, 140 miles.
Emptied garage of trash, saved best Volvo parts.
Dropped her off for two new keys and fob, and heat core change
Drove Juliette the Miata killer home. The Idiot Man Light came on 30 miles from ferry, filled up with 13.5 gallons on Long Island
The white colo(u)r 245 DL with DC plates, not one of the 50 States
- rudsaki
- Year and Model: 1998 S70 T5
- Has thanked: 26 times
- Been thanked: 15 times
following Amblerman write up of using ABS cement
Previous Volvos
1969 142s Blue manual.
1966 122s Yellow with the 69 motor in it
1971 144s Red . Also the '69's motor
1973 P1800ES Aqua Manual with OD.
1971 142E Light Blue manual with OD.
1979 244DL Brown manual. Marriage/baby car. Divorce, Ex got it and sold it to my father!
1968 1800s White manual/OD. Strong runner. Killed by a '66 T-Bird
1984 242 Turbo Intercooler Silver Manual/OD
1966 1800s White Manual/OD
1985 740 Turbo Intercooler Silver Manual/OD Sold to Nephew
yanga001
- Has thanked: 59 times
- Been thanked: 110 times
Have 2 fuel pumps to do (98 s70 and a 99 S70 T5). Have not started those cars in over a year and the pumps aint priming. Trying to find a fuel pump tool for the rings now.
00 S70 Manual started right up, its engine looks pretty good and she had a smooth idle. Life found a way to keep me away from these things.
The major projects coming up would be the engine swap for the 98 V70, figuring out what i can do about a seized lower u joint, and potentially rebuilding 2 steering racks for the manual and the s70 T5. Both have boot leaks and it could be entertaining to try and rebuild a rack.
2008 S60 2.5T Auto (Sold)
Steering column? That’s a junkyard only part , now.figuring out what i can do about a seized lower u joint,
Slow;y transitioning cars to my new life still
Shagg carcass hauled away next week after harvesting 99 00 only spindles and steering rack
Buyer for engine lined up
Juliette the Beetle is being a good daily driver, so letting me work on other cars
Abs module in the p2 out
Buyer for the E83!
Karla doing duty as my Albany Driver..she will end up in Bridgeport so I can run up to Boston for $10 ferry instead of taking car for $70. Also don’t have to reserve passenger ferry ride
NewGene the xc90 needs nothing!
Need to fix brakes on the T4 camper
Need to tap cylinder head cover on T5
RedBrickCollector
- Year and Model: 1997 850 T-5 Wagon
- Has thanked: 40 times
- Been thanked: 28 times
Found a parts car with small bits I needed. Got the carpet for the third row seating area and a center arm rest with intact cup holders as a highlight.
Is every car with third row seats supposed to have the small bits of carpet that cover the metal bars on the side, the frame for the other floor panels?
Also, I got a second side mirror because my left/right seems to be disconnected. Would it be possible to change the mechanisms over? also the second side mirror might have a disconnected up/down. By disconnecte I mean not only do the controls not work, but I can press down on it to move the mirror with nearly no resistance
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
