(You're preaching to the choir, in my case.)
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
1999 V70 GLT
1999 V70 GLT
- Has thanked: 1507 times
- Been thanked: 3824 times
Dr Oetiker here…you will assimilated! Clamping resistance is futile…
- Has thanked: 305 times
- Been thanked: 517 times
- Sveedy
Started back on rebuilding the head for the 850. Thanks to that evil Dr. Oetiker
, I have some new valves on the way, so my schedule has moved up a bit.
A couple of the other valves also had quite a bit of carbon build up on the stems, so looks more and more like bad stem seals.
1999 V70 GLT
1999 V70 GLT
Be careful with those broken valves. I’m not quite sure where the Metallic sodium is but that is not to be played with
I’ve always wondered what exactly happens here. Does a poor seat inhibit heat transfer and the valve metal softens to failure? What causes that gouging, is it hot gas acting like a torch or melting again?
- DennisCA
- Year and Model: 1996 850
- Been thanked: 59 times
I took a pause from the 850 after I did some filler work and I needed to get some supplies too for painting. But tonight I got most of the stuff i needed and I've put a seal coat of 2k epoxy on one fender to start with.
So the idea is to let the epoxy cure, scuff it with P320 perhaps, then go to a high build primer, then metallic base coat, then 2k clear coat.
A lot happening tonight, a person dropped by and sold me these aluminum link arms too
- Sveedy
My uneducated guess is that oil seeps down the stem when the engine is not running and sits there. Then when the engine fires up, that oil cooks off, but maybe leaves a little bit of residue. Repeat and repeat, and the build-up must get thick enough to retain the heat till one explosion and it blows that piece out. I'm imagining something like an oxyacetylene torch when you hit the oxygen lever.
1999 V70 GLT
1999 V70 GLT
- Has thanked: 928 times
- Been thanked: 1002 times
It sure looks like result of torch.Sveedy wrote: ↑26 Jul 2025, 14:19My uneducated guess is that oil seeps down the stem when the engine is not running and sits there. Then when the engine fires up, that oil cooks off, but maybe leaves a little bit of residue. Repeat and repeat, and the build-up must get thick enough to retain the heat till one explosion and it blows that piece out. I'm imagining something like an oxyacetylene torch when you hit the oxygen lever.
I think the sodium is in the stem only.
