Volvo 850 2000t 20v
xrevoltadox
Year and Model: Volvo 850 GLE 2000 T
Post by xrevoltadox »
Hello i have an problem in my volvo, i have repair black smoke in the exhaust pipe and a lot of fuel consumption.
Can you help me?
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
What year is your 850? And what exactly is your problem? I understand you have excessive fuel consumption, but what do you mean by "i have repair black smoke in the exhaust pipe?" Have you checked to make sure your airbox isn't stuck to the hot air side? Do you have any codes or is the CEL on?
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Could be a number of things like Maf,o2 sensors,vacuum leak...Read your codes and post'em here and than we will be able to help you.
If your car is '93-'95 you can read the codes yourself.Like this:
http://volvospeed.com/CheckEngine.php
If it's '96 or later you'll need scan tool/code reader to read the codes.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
xrevoltadox
hello my is 1996, black smoke appears when the engine is hot when it keeps idling, already changed thermostat, pressure sensor of gasoline, spark plugs, spark plug cables, maf, rotor, distributor plate.
polskamafia mjl
Go to advanced or auto zone and have them read your codes for you, or borrow one of their scan tools. Post the codes back here and we can start figuring out what's wrong. Black smoke usually means you're burning oil so my first guess is that you have an oil leak. When was your last oil change and what kind of oil are you using?
Oh, and, just out of curiosity, what does "2000t" mean? lol
xrevoltadox
I use castrl txt 10-40 syntetic.
polskamafia mjl
Ok. When you say you changed the thermostat do you mean the one in the airbox? If so, are you positive that the aribox is working properly? Until you get the codes read and post them there isn't much else that can be done. Like I said, I'm pretty sure that it's an oil leak.
Airbox -> https://www.matthewsvolvosite.com/forums ... hp?id=1321
misha
Post by misha »
polskamafia mjl wrote:Black smoke usually means you're burning oil so my first guess is that you have an oil leak.
Black smoke means that car is running rich! :!:
When engine burns oil smoke colour is BLUE!
Check the codes and we will try to help you out.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
polskamafia mjl
Good point Misha. lol Either way check the codes.
xrevoltadox
Hello my dont have any code errors , and my airbox dont have this termostat
My car is 2000cc turbo 180 hp europe verson
