I noticed my warning lights would appear as soon as i hit about 3,000 PMs and release the gas to coast. They then would go off as soon as i gave it gas again. Once i got to work i sat in the parking lot and tested it. In park i would give it enough gas up to 3,000 RPMS and let go, the lights would come on and stay on. They wouldn't go back off again until i gave it some more gas. My Gas light, and Service light were the two brightest of the lights that came on and the rest were a on but, not as bright. I just purchased a battery from Wal-Mart abou three months back and decided to get the battery tested to see if perhaps that might have been the issue. They tested my battery, my starter, and my alternator and all came out good. The alternator not loaded was pushing 14V and loaded was pushing 12V loaded just being my radio and blower, my AC doesn't work. The tech said it could possibly be the alternator but, I would hate to spend all that money and not now for sure. Someone else told me that the fuel pump might be causing the problem.
The below information might help because I never had this problem until this happend. Read BELOW
As i was backing out of the driveway at about 6:30AM in the monring all the sudden my horn just starts going off by itself. I immediately cut the car off w/o puting it in park to prevent from waking the neighbors, I unplugged the horns and went off to work. Noticing the issue on my way to work.
Thanks Ahead!
850R 1996 Warning lights come on during acceleration
Warning lights come on During Acceleration
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Sounds like you have some sort of short circuit.
Your alternator have normal charge of 14v without any load...but when you turn on accesories it falls down to 12v.
12v from the alternator means that alt isn't charging.
Check the grounds and b+ terminal and also battery terminals for corossion or loose.If they look greeny or dirty you need to clean them up with baking soda or alcool with a tooth brush.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
confused_al
- Year and Model: 1996 TLA wagon
Have you checked your drive belt? If its loose and/or slippery, check you belt tensioner, idler and belt itself.Aramelli wrote:as soon as i hit about 3,000 PMs and release the gas to coast. They then would go off as soon as i gave it gas again.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
The Belt is giving barely a half inch of slack, belt appears to be good and i'm not to sure on what to look for on the tensioner. I would assume try to loosen and tighten it but, it looks like i don't have the required tool for that. Also I'm sorry i mis understoood the tech at walmart, the printout of the test shows 13.01V no load and 12.96V loaded. I tried cranking it today and it really had trouble turning over, it gave it it's all and finally gave up. Then on the second try it turned over and all my warning lights were on and my headlights and inside lights were really dim. As soon as i gave it gas my warning lights went off my head lights and my interior lights brightened back up to normal. I'm beginning to suspect that my battery is defective. Sadly it tested good.
confused_al
From what you described, it does sound like your alt is getting weak. If my old age memory serves me right, it should be 14v+ w/o load.
Did you check the alternator's cable terminals? Cleaned them?
If that is not it, replace an alt is not that expensive, FCP sells rebuilt one for $235 (http://www.fcpgroton.com/product-exec/p ... ory_id/111), thats before 10% discount they give here.
Here is the write-up for replacing it
http://volvospeed.com/vs_forum/index.ph ... placement/
GL!
GL!
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
9394volvo850s
- Year and Model: 93 850 5spd 94 850T5
I agree on atlernator being faulty if the lights are dim until u rev it up. change it or you will need a battery too..
93 850 5spd 320k (the daily)
94 850 T5 190K (race car)
95 T-5R wagon yellow (summer wag)
90 745 5spd 295k (winter wag)
67 122 2 door 4spd 69k
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
I don't believe that turning the car off in reverse has anything to do with your problems. 2 weeks after I got my 850 I spun out into a corn field after a heavy rain. My car was rolling backwards while in drive (aka, it should have been going forward), so I pressed the brake pedal and turned off the engine while in drive. After all of this, the only thing that broke was the odometer gear.
- Has thanked: 2857 times
- Been thanked: 1332 times
If you can, take photos as you go along and I'll post them here (or you can) in a new topic.
Thanks in advance if you do this.
- 15 Replies
- 4306 Views
Last post by Eastema
- 1368 Views
Last post by sbattaglia
- 1013 Views
Last post by E Showell
- 15 Replies
- 7203 Views
Last post by WarbirdPilot91
- 1646 Views
