the saga continues
the saga continues
First let me thank you for all the help in the past posting. I have an S80 T6 that I was having to refill with anti freeze over and over, advice given was to look for hair line crack on green lid and fill tank, how ever I found that I was leaking anti freeze from the plastic conection where the heater hose goes. My question is that plastic piece a part of the heater coil? CanI replace just that tip? If so how do I get it off and what is it called.Thanks in advance for any help I can get on this. This site Rocks!!!
OEMVolvoParts
- Year and Model: ALL
There are two heater hoses that go into the firewall, an inlet and an outlet. That plastic piece is part of the hose itself, when you buy the part it all comes as one. Part numbers are 30745299 and 30745330. The hoses are fairly common problems.
