Service light reset for Volvo V40 and S40 Topic is solved
jsnyder
All models for 1999 and on can be reset by putting the ignition key into position I, push in and hold the odometer reset button (use your left hand), move the ignition key to position II, when the service light begins to blink,let go of the odometer reset button. Confirm by turning your Volvo off then on again.
della
Tried all the usual procedures but all failed.
Set to position 1, pushed in odo, turned to position 2 then have to hold for 2 minutes before goes out then no flashing or beep. Start car and ok, turn off and start again, service light back on. Must be missing the final step somehow. Help !!
alfonzobonzo
- Year and Model:
480 L 1994 2.0 i Metalic Black K&N Panel
V40 W 2000 1.9 T4 Metalic Black
Guest
S40/V40 SERIES SERVICE LIGHT RESETNicholas wrote:How do you reset the service light on the dash????
RESETTING SERVICE LAMP ON 1999 S40/V40
1, Hold down the odometer button
2, Turn the ignition so all the lights come on
3, Keep holding the odometer down for 30 secs or until the service light starts flashing
4, Release the odometer button
ive just done my 2001 s40 no problem release button as soon as the service light flashes....
LaoFuZhi
Must be different for older models.......
If anyone knows the procedure for a '97 Diesel I'd be obliged....
Can a tool be made up? (I'm experienced with electronics so building wouldn't be a problem)
harvey7
thanks JSNYDER,
The procedure you quoted to reset the service light worked.
I dont know if anybody knows but there are people trying to sell this information on ebay.co.uk.
Thanks again.......... [/quote]
John D
Do mind sharing the this knoledege with the rest of us?
I've got a 97 V40 T4.
What is the procedure for reseting the service light?
John
John
alfonzobonzo
- Year and Model:
ermmmm????Do mind sharing the this knoledege with the rest of us?
its in this post???
look up
- 4251 Views
Last post by theWIFES_S70
- 1258 Views
Last post by mf70
- 27 Replies
- 7624 Views
Last post by Blockpartie
- 13 Replies
- 6089 Views
Last post by esl_97_850_T5
- 1894 Views
Last post by precopster
