'90 740 turbo runs poorly
740turbo_JD
- Year and Model: 1990 740 turbo
I have a 1990 740 volvo turbo. Its been sitting for a couple months now. my car will start but when i take of and just start to get going, it slowes down and act likes it will die. this is as im pressing the gas. if i take my foot off the gas it stays running but still wont move. please help me. Im thinking it has something to do with the fuel line
Reason: Removed "HELP" from title. Please read the READ ME pinned to the top of the forums. http://www.matthewsvolvosite.com/forums/viewtopic.php?f=2&t=8860
steve smith
- Year and Model: 1993 volvo 940 turbo
I dont know if it is the same problem but the issues you are speaking of were the same I was having with my 940 turbo.It turned out to be a dirty mass airflow sensor bought maf cleaner sprayed it out let it dry disconnected the battery to reset my codes. Then reinstalled maf sensor waited 15 minutes reconnected the battery and my problem was solved.it definately sounds like a fuel issue so I hope this helps our at least gives us somewhere to start>my car sat for 5 months when parked it ran fine then when got going again I had this issue
740turbo_JD
thanks alot. I will try that right now and see what happens.
- 47 Replies
- 8407 Views
Last post by E Showell
- 382 Views
Last post by Ozark Lee
- 1173 Views
Last post by SuperHerman
- 2120 Views
Last post by 3p141592654
- 32 Replies
- 6434 Views
Last post by aaron1611
