i have just replace the headgasket on 95 glt 850 sedan and have reassemble all parts.when i turn the crank shaft i could only turn it a little
before i hit something i think it's a valve.so i turn it counter clock and i can turn is maybe a 1/4 turn then hit something.does anyone have any ideas on what to try next.other than taking the crank cover off again.
crank shaft position with timing belt
- Year and Model: Many Volvos
- Been thanked: 76 times
Everything needs to be lined up to the timing marks before the head goes on. If you are way off the only thing you can do is take the head off again, get the crank shaft lined up with its mark, and then lock the cams in their #1 TDC position prior to torquing the head down.
If you don't have a Haynes Manual go buy one, it shows how to make the tools to lock the cams in the correct position to re-install the head.
FCPEURO
- Year and Model: 2006 XC90 V8
- Been thanked: 19 times
+1, you're lucky nothing got messed up while you were torquing everything down. Pull the head, line everything up correctly, reinstall the head.
i have everything on i am trying to turn the crankshaft the 2 rotation like the book said to do to make sure everything is OK witch it isn't something i know i did was not rightOzark Lee wrote:Everything needs to be lined up to the timing marks before the head goes on. If you are way off the only thing you can do is take the head off again, get the crank shaft lined up with its mark, and then lock the cams in their #1 TDC position prior to torquing the head down.
Is the timing belt on?
Double check all of your marks.yes every thing is on .
Do you have the spark plugs out? You may just be hitting a compression stroke.
Please back up and describe everything you have done thus far with particular emphasis on where the timing marks were coming off and going on. Also describe which camshaft slot was above and below the casting on the lower head when you locked them down.
i place the crankshaft pulley and camshaft sprockets to the alignment mark then remove everything down to the lower cylinder head.had the lower head machine and valve job then reinstall lower cylinder head to the torque setting. reinstall the upper cylinder position the camshafts slots parallel to upper surface. O ok hear is where i might have gone wrong i seem to remember positioning the slot parallel to the lower cylinder head.opps:will redo the upper and place the correct camshafts position. will let u know how it turns out.thanks for your help .
i had time today so i took the upper cylinder and found that i had place the cams shaft in the wrong position i had the intake cam in the exhaust position and the exhaust cam in the the intake .i know i will be good from hear on.thank you all.
- 3655 Views
Last post by Empathron
- 967 Views
Last post by GBS
- 3620 Views
Last post by bluesguys80
- 5404 Views
Last post by SuperHerman
- 723 Views
