C70 jan2000 idle speed erratic
hi guys my c70 idles erratically constantly jumping and falling between500rpm and 1200rpm any ideas what the problem could be. also any ideas where i can get a repair manual for this car as haynes manuals finish at 1999 for this particular vehicle
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
No manual unless you want to buy the VADIS DVD discs that often come up on eBay. What you have sounds like a bad MAF (mass airflow sensor). You need to have your diagnostic codes read with a scan tool to be sure. AutoZone will do this for you, among other places.
Thanks for the info MadeInJapan keep you postedMadeInJapan wrote:No manual unless you want to buy the VADIS DVD discs that often come up on eBay. What you have sounds like a bad MAF (mass airflow sensor). You need to have your diagnostic codes read with a scan tool to be sure. AutoZone will do this for you, among other places.
I had the same issue over the past few weeks on my 2001 vehicle (its the 2.0 LPT version).
What I found was that it was actually the fuel injectors that was the cause and they just needed to be cleaned with an additive.
I added 1 12oz bottle to a full tank of fuel and as my car has 50k on the clock repeated the procedure when I next needed to fill the tank as I wouldnt say they had been cleaned before.
Car has been running fine since!
Added a link below to a similar additive to the once I used. Hope this helps you out.
http://www.federalmogul.com/en/Aftermar ... orCleaner/
- 614 Views
Last post by Bluegrassxc70
- 3448 Views
Last post by precopster
- 1433 Views
Last post by metalriff
- 1020 Views
Last post by saulgar1
- 1683 Views
Last post by mattmatt
