New How-To: Install Spark Plugs 850/S70/V70/C70
This topic is in the MVS Volvo Repair Database » Spark Plug Change Tutorial: Volvo 850, S70, V70, XC70, C70
aldug
Year and Model:
Post by aldug »
Zeek, I have the same car and I recently removed the spark plug cover without removing the pipe. You just need to get creative with ratchet extensions and universal joints.
zeek
Year and Model:
Post by zeek »
Aldug, without removing the pipe I can't lift the right end of spark plug cover high enough to slide it out from under the pipe. Any suggestions?
Thanks zeek
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Zeek, on our '04 V70, instructions said to remove the IC (turbo) pipe, but I said fooey. Sure enough with some wiggling, I got the cover off and out without taking the pipe off. I used no connectors, a long one on some as well as an "L" shaped torx wrench to get the torx screws out.
stuartehamilton
Year and Model: 850 1994
Post by stuartehamilton »
Spark plug distributor / diagram
coldax
Year and Model:
Post by coldax »
How often should I be replacing the plugs?
2000 S70 with N/A engine.
Thanks,
Coldax
2015.5 V60 T5 AWD Platinum
2012 XC60 T6
2012 S60 T6
2011 S40 T5
Gone but not forgotten:
2009 C30 R Design Sold to buy more Volvos
2007 S40 2.4 t-boned and totaled :evil:
2010 V50 2.4 hit a deer and totaled :(
2000 V70 SE head gasket :cry:
2000 S70 SE sold with 240,000
JimG
Year and Model: S70 T5 1999
Post by JimG »
I have a 1999 S70 T5. When I took off the plastic cover over the plugs my visual is not the same in the tutorial as shown in steps 1 thru 5. I don't have a heavy duty rubber cap for each plug instead I have some sort of plastic retangular box for each plug. I was hesitant to try to remove them till I get further clarification. I think being a turbo is the result. Any pics for a T5 spark plug change? Thanks
Jim 8)
mindshadow
Year and Model: none
Post by mindshadow »
Just take the screws off, those rectangular things are the same as the rubber caps. Same principle as the pre-'99 models, just a slightly different design.
renns
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 6 times
Post by renns »
Is anyone else worried about debris falling into the combustion chamber as the plug is removed? Given the plug is way down at the bottom of that hole, it seems any crap that falls into that area will drop through the opening when the plug is removed. In an attempt to clean the area before plug removal, I break the plugs loose, and then use a shop vac to suck out the plug area. Overkill?
I also use the rubber hose to remove the plugs as well, once loosened. That way any std deep socket can be used.
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
C@lvin
Year and Model:
Post by C@lvin »
quote="coldax"]How often should I be replacing the plugs?
[/quote]
Some say 30K for the OEM Volvo plugs and 10K-20K for Bosch copper. Anywhere between these should be fine unless your plugs start having problems sooner.
JimG wrote:I have a 1999 S70 T5. When I took off the plastic cover over the plugs my visual is not the same in the tutorial as shown in steps 1 thru 5. I don't have a heavy duty rubber cap for each plug instead I have some sort of plastic retangular box for each plug. I was hesitant to try to remove them till I get further clarification. I think being a turbo is the result. Any pics for a T5 spark plug change? Thanks
Jim 8)
Those plastic rectangular boxes are your individual ignition coils. Beginning with MY 99 the ignition is electronically controlled, so instead of one external coil and a distributer, you have individual coils and ignition is controlled by the computer. But for changing the plugs, you just remove the retaining bolt for the coil and everthing else is pretty much the same as before.
I've never run into much of anything down there but it would provide "cheap insurance" to either vac or blow with compressed air to clear the plug well. I wouldn't call it overkill, just precaution.
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
I use the poor man's shopvac: canned air. You know, those keyboard cleaners/photo duster cans.
But I use the red little hose they come with and point it down the hole, otherwise tipping the can to point the stream down releases liquid, not gas.
Also -> Amazon link
