The volvo control arms have replaceable bushings and ball joints. It's a win win situation and they last alot longer than the cheap aftermarket variations. I have tried the cheap, actuall have scantech arms on my 850 right now, but this is the second set and when the ball joints let go im buying stock volvo arms so I can just replace the ball joints as they go, haven wore out a bushing yet.
curtis
Ball joint/control arm survey
Ball Joint / Control Arm Survey
renns
- Year and Model: 2005 XC70
- Has thanked: 3 times
- Been thanked: 6 times
I know the earlier 850's had a replaceable ball joint, mounted via a line of three bolts. Later models have the ball joint pressed into the casting. Is that latter version easily replaceable as well? Do you know where to buy the joint only?Japedo wrote:The volvo control arms have replaceable bushings and ball joints. It's a win win situation and they last alot longer than the cheap aftermarket variations. I have tried the cheap, actuall have scantech arms on my 850 right now, but this is the second set and when the ball joints let go im buying stock volvo arms so I can just replace the ball joints as they go, haven wore out a bushing yet.
curtis
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
I believe u can order the ball join through fcp, or napa or volvo. U are right about the 3 bolt attachment of the balljoint. It's a good setup, my 01 xc is the same.
I have no idea about the later version, only delt with the 94 850.
Maybe if u do have to replace your arms go with the earlier "relaceabke ball joint" version if it's possible.
curtis
curtis
2003 v70 2.5tawd black/black 120miles
2007 nissan altima 2.5 cvt 107miles
2001 xc70 211 miles " collision"/ parts car
1994 850 turbo 315miles 5 speed "stoped fixing it"
schigara
- Year and Model: 96 850 T5 Platinum
I just replaced both A-arms with the $38 ones from FCP. Considering it only takes less than 30 minutes per arm to change, I don't care if they only last 1-2 years.
Also, I'd like to hear from the group that has bought the cheaper version that their a-arms are still going strong after 2-5 years? You always hear about the failures but rarely do people comment when nothing goes bad.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
I thought that on later models of 850 it was impossible or at least impractical to replace just the ball joint...
I doubt u will hear great success stories in regard to scantech control arms. They might last more than a year if u don't drive your car. BUt from what I have found and others will likely agree they last about 14mnths, "2 mnths past their warranty" or aprox 25thousand kms. Mind u I do drive alot of rough backrds with my cars. A city car or mostly highway car might do a bit better.
curtis
curtis
Craigd2599
- Year and Model: 2007 S40.
I just got mine last week and installing them this week. My thoughts were exactly the same. If I get one year out of them, it will find me in a better financial state in one year and maybe then I can buy OEM. We need a Volvo Parts Czarschigara wrote:I just replaced both A-arms with the $38 ones from FCP. Considering it only takes less than 30 minutes per arm to change, I don't care if they only last 1-2 years.
No we don't!
Craig D
Philly Boy in Lynchburg VA
2007 S40 Previously: 2 850's and an S80
Waiting for that "R" model barn find
monty
- Year and Model: 2000 V70XC SE
- Has thanked: 2 times
funny you should mention ball joints! I was under my '00 v70xc today to set toe-in and happened to look at the ball joint/control arm I changed 2 years ago with probably only 10,000 miles on - the rubber boot over the ball joint is totally disintegrated!!! I'll check my receipts to see what I bought, but I do usually shop by price
, but completely gone in two years ??? 40 years of home wrenching that's a new one on me!!!
'00 XC70 SE 240,000mi. - a real car
kiss4afrog
- Year and Model: 850 1995
- Been thanked: 2 times
I know the earlier 850's had a replaceable ball joint, mounted via a line of three bolts. Later models have the ball joint pressed into the casting. Is that latter version easily replaceable as well? Do you know where to buy the joint only?[/quote]
Most parts stores should be able to source the ball joint with the bolts separately. I know Oreilly and Autozone both carry ones for mine.
The ones with the pressed in ball joint, the ball joint is not replaceable seperately that I know of. In the case of the pressed in ones you have to replace the whole arm.
- Control arm, lower.jpg (12.51 KiB) Viewed 1763 times
- suspension front ball joint.jpg (15.71 KiB) Viewed 1763 times
You can never have too big a Turbo !
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
I have the URO's from FCP. The passenger side is still tight after 50k.
I wiped the drivers side out on a pothole that also bent the wheel and blew out the strut. I can't fault the control arm on that one.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- 10 Replies
- 4740 Views
Last post by oragex
- 15 Replies
- 3750 Views
- 4197 Views
Last post by Tonyx
- 12 Replies
- 5629 Views
Last post by darrylrobert
- 9 Replies
- 7200 Views
Last post by BrianV70
