I have been having slow starting issues with my 850 (191,000 miles), and decided to check the connections to the starter. I followed directions on this site, removing the battery, battery shelf, and the fan to access the starter. I reached the starter, and cleaned off the cables and the connection to the starter, and applied petroleum jelly to the connections. When I put it all back together and tried to start it, it was just cranking, and would not start. The engine is turning over, but will not start.
Any tips on what I should check? Is it possible that it could be the spark plugs?
850 GLT 1995 Cranks but won't start
Well checking the codes would be a good idea. But a quick check for spark would be to unoplug the wire going from your coil pack to the distributor. Hold it aprox 1/2 an inch from the coil where it was plugged in before u seperated it. Have someone try to start the car at this point, if you are getting fire to your plugs you should see blue electricity bridge the gap. Ive been told that there is a risk of shocking yourself with this method but I have used it a couple times without getting shocked.
If you do indeed have no spark, I would bet that your cam shaft position sensor has let go.
Ive had it happen twice. But again reading the codes is an easy way to figure this out.
good luck
Curtis
good luck
Curtis
2003 v70 2.5tawd black/black 120miles
2007 nissan altima 2.5 cvt 107miles
2001 xc70 211 miles " collision"/ parts car
1994 850 turbo 315miles 5 speed "stoped fixing it"
- pkc303
- Year and Model: 1995 T-5R Yellow
- Been thanked: 3 times
When we had the no start problem, turned out to be the fuel pump. We changed it ourselves.
Eric and Evan
Eric and Evan
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
Ok, so I just learned how to check the codes, and here they are:
A1- There was physically nothing in this slot
A2- 111
A3 ABS
211- Left front wheel sensor, not signal on moving off
212-Right front wheel “
213-left rear wheel “
214-right rear wheel “
141- Faulty pedal sensor, shorted to ground or supply
142- Faulty brake pedal switch, open or short
A5-also physically nothing in this slot
A6- 111
A7
122- Temp. sensor interval too short
113-Fuel gauge open circuit
231-
B1-nothing there
B2- 122
B5-nothing there
B6- no reading
Would any of those reading cause the car to not start? And why would my volvo ('95 850 glt) not have anything in holes A1 and A5? Is that because it is a manual transmission?
Thanks.
A2- 111
A3 ABS
A6- 111
A7
231-
B1-nothing there
B2- 122
B5-nothing there
B6- no reading
Thanks.
Craigd2599
- Year and Model: 2007 S40.
- Has thanked: 3 times
122 temp sensor will cause a hard / no start Its the ECT. it'll cost you $20 and 15 minutes to change it out
Craig D
Philly Boy in Lynchburg VA
2007 S40 Previously: 2 850's and an S80
Waiting for that "R" model barn find
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Since you needed to remove radiator fan....then you needed to unplug the main fuel system relay(it's the grey one one the fan carrier).
If it's unplugged...connect it and your car will start.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Year and Model: Many Volvos
- Been thanked: 76 times
I think Misha is pointing you in the right direction. The Master Fuel System relay is the gray relay towards the drivers side of the car on the fan shroud. If it is not plugged in it won't run and even if it is plugged in it may or may not work, the wires are all exposed and they are susceptible to being damaged. Many times when the master fuel system relay has issues you will not hear the idle air control valve buzzing when the key is in position II.
You will have no port A-1 with a stick - it is only for the automatic transmission cars.
Ok, so i did hear a buzzing when the key was in position II. I checked the grey relay and made sure it was plugged in. This time when I tried to start it, there was a strong cranking (I'd had the battery attached to a charger), and then it kicked on just briefly for a second, seemed to run kind of roughly but very briefly, then shut off. When I tried it again, it just cranked and wouldn't kick on.
Check the manifold vacuum lines while you're there checking the master relay. Have you tried seeing if there is fuel getting to the rail ? There may be a small metal screw cap at the end of the rail covering what looks like a tyre valve press that as you crank the engine.
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
- 10 Replies
- 4451 Views
- 34 Replies
- 6713 Views
Last post by esl_97_850_T5
- 971 Views
Last post by Ozark Lee
- 978 Views
Last post by seattle850
- 192 Views
Last post by misha
