Hey you guy have helped me out a lot so far but now i found out my radiator is cracked and I need to find a new one any suggestions my mechanic said it would cost about $300-$350 so if you know of anywhere that i can get one for cheaper please let me know
I have a 2000 S70 T5 or Turbo awd not sure any more
Radiator Help
confused_al
- Year and Model: 1996 TLA wagon
Call DW Volvo
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
FCPEURO
- Year and Model: 2006 XC90 V8
- Been thanked: 19 times
This radiator is only 265 and is a very good one.
Also, if you have your mechanic install it, you will get a lifetime warranty on it.
Is it cracked at the upper radiator hose fitting? Mine is with 133k miles on it. It leaks out only when sitting overnight. I have a new radiator waiting ($170 - I have a connection with a local parts warehouse) and plan on putting it in this weekend, just contemplating replacing the heater core o-rings at the same time...
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
evan023, as far as I know there is no such thing as an AWD s70. To find out, though, look underneath the back of the car and see if you have a rear differential, if you do then you do indeed have an AWD s70.
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
They made an AWD S70 in the model year '99...maybe '00 too. A neighbor had one.
Yeah that radiator I got has the wrong fittings for my oil and transmission cooler lines. My car and original radiator has the clip-on style and the replacement radiator has the screw-on style. Will not work. Need to find another radiator. Things to keep in mind whilst shopping around.
Make sure you get a Nissen if you don't get factory. Then you are sure it will fit.
- 279 Views
Last post by volvolugnut
- 3658 Views
Last post by t3yf5g
- 9 Replies
- 7206 Views
Last post by jalwlb
- 1371 Views
Last post by CEBirnley
- 1022 Views
