oil trap
mindshadow
- Year and Model: none
As in can you clean it out? I think it depends on how clogged it is, as I've *heard* of someone I know who is a Volvo lover that cleaned their system with some really high pressure air. Obviously they disconnected it from the car before doing it.
But honestly the kit to do it is only like $92, so you may as well replace everything.
http://lakesidedp.com/uploadpics/pcv/
It's a lot of work to change it. I poured a half can of SeaFoam into mine and it works fine now.
waynej
99 S70
96 854
87 245 wife's car
94 850 sons car
94 850 2nd sons car
Previous Volvos
93 850
87 744
85 244
82 244
80 244
78 244
78 245
76 265
71 P1800
71 142
99 S70
96 854
87 245 wife's car
94 850 sons car
94 850 2nd sons car
Previous Volvos
93 850
87 744
85 244
82 244
80 244
78 244
78 245
76 265
71 P1800
71 142
shagginwaggin
- Year and Model: 1994 850W 5sp
The oil trap, itself, is only about a $35 dealer part. The associated hoses, if not cracked and old, can be reused. The only other must-replace part when you do the oil trap is the intake gasket.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
No, the power steering lines can apparently be bent out of the way but there is no way to remove the pan w/o doing something to the PS lines.
- Year and Model: Many Volvos
- Been thanked: 76 times
Easy deal, a new rear intake camshaft seal will fix it right up. It is an easy repair compared to most - yank the old one out and tap in a new one. The hardest part is taking the distributor off but even that is fairly easy.Any suggestions on the oil coming from behind my distributor?
Weird! I bought the Chilton's manual for my recently acquired '97 850 s/w and there is no mention of the oil trap at all in there. Does it have another name? I tried "oil separator" as well - no mention of that either.
I have seen the detailed procedure written in Oct 2005 by "White850Turbo" for replacing the oil trap, but that was for his turbo; mine is not turbo, but I assume everything else is pretty much the same. Is that right?
Thanks
Thanks
- 2256 Views
Last post by mikealder
- 32 Replies
- 6073 Views
Last post by misha
- 823 Views
Last post by erikv11
- 1322 Views
Last post by ordinaryboy1986
- 13 Replies
- 2373 Views
Last post by Sommerfeldt
