oil trap
zuni97
Year and Model: 1994 850 wagon
Post by zuni97 »
Can the oil trap be serviced or is it a throw away part?
mindshadow
Year and Model: none
Post by mindshadow »
As in can you clean it out? I think it depends on how clogged it is, as I've *heard* of someone I know who is a Volvo lover that cleaned their system with some really high pressure air. Obviously they disconnected it from the car before doing it.
But honestly the kit to do it is only like $92, so you may as well replace everything.
http://lakesidedp.com/uploadpics/pcv/
waynej
Year and Model: 1999 S70
Post by waynej »
It's a lot of work to change it. I poured a half can of SeaFoam into mine and it works fine now.
waynej
99 S70
96 854
87 245 wife's car
94 850 sons car
94 850 2nd sons car
Previous Volvos
93 850
87 744
85 244
82 244
80 244
78 244
78 245
76 265
71 P1800
71 142
shagginwaggin
Year and Model: 1994 850W 5sp
Post by shagginwaggin »
The oil trap, itself, is only about a $35 dealer part. The associated hoses, if not cracked and old, can be reused. The only other must-replace part when you do the oil trap is the intake gasket.
zuni97
Post by zuni97 »
Tried the seafoam method....seemingly little success oil now leaking from behind distributor
also, is there easier way to drop the oil pan without removing the power steering lines?
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
No, the power steering lines can apparently be bent out of the way but there is no way to remove the pan w/o doing something to the PS lines.
zuni97
Post by zuni97 »
I was afraid that was the case with the ps lines I just wanted to confirm.
Any suggestions on the oil coming from behind my distributor?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Easy deal, a new rear intake camshaft seal will fix it right up. It is an easy repair compared to most - yank the old one out and tap in a new one. The hardest part is taking the distributor off but even that is fairly easy.
zuni97
Post by zuni97 »
Thanks for the diagnosis...shooting at this weekend to do work...will reply with my results
thanks
barrylay
Year and Model: 1997
Post by barrylay »
Weird! I bought the Chilton's manual for my recently acquired '97 850 s/w and there is no mention of the oil trap at all in there. Does it have another name? I tried "oil separator" as well - no mention of that either.
I have seen the detailed procedure written in Oct 2005 by "White850Turbo" for replacing the oil trap, but that was for his turbo; mine is not turbo, but I assume everything else is pretty much the same. Is that right?
Thanks
