fuel pump relay
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Check for power at the fuel pump.golfman wrote:suspect fuel pump relay faulty,1999 v70,,,any testing suggestions?
- Year and Model: Many Volvos
- Been thanked: 76 times
Using a paper clip to jump between the socket positions associated with pins 15 and 87 on the relay is the procedure to by pass the relay itself. If the car runs OK the relay was bad, if you still have no fuel pressure then the fuel pump itself is likely bad.
4 terminals----15,87,31b,31 which do i jumper across?.... 87 seems to be 12volt hotOzark Lee wrote:Using a paper clip to jump between the socket positions associated with pins 15 and 87 on the relay is the procedure to by pass the relay itself. If the car runs OK the relay was bad, if you still have no fuel pressure then the fuel pump itself is likely bad.
Put the jumper wire, a paper clip or whatever, between the socket positions associated with pins 15 and 87.
point taken lee,,tired yesterday did'nt read aswer thoroughly,,,,did that, still no pressure at fuel rail,,,also reading 0.5 ohms across those terminals,, with ign on,,,read somewhere should be 1.5,,any more recommendations?,i'm not so tired today, son needs to get back to school in this machineOzark Lee wrote:Put the jumper wire, a paper clip or whatever, between the socket positions associated with pins 15 and 87.
If you have a voltmeter as it appears you do, check to see if there is 12 volts at pin 87 when the key is on. If so, listen to see if the fuel pump runs when the key is turned on (before turning it to start). If the relay has voltage but the pump doesn't run, as suggested above, check to see if there is voltage at the electrical connector to the fuel pump itself. I'm not that familiar with the connectors, but I think they are accessed through a plate in the back floor of the V70. I have an AWD myself which has the pump in a different location.
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
- 5215 Views
Last post by wizechatmgr
- 11 Replies
- 2809 Views
- 16809 Views
Last post by Richard99
- 19 Replies
- 9586 Views
- 17 Replies
- 7689 Views
Last post by cn90
